need to extrude all polylines on the same layer
Hi all
I have drawing that consists of lets say 20 different layers and multiple polygons.
I am trying to write a script that does this:
1-  make layer L1 the active layer (isolate, etc)
2- select everything on layer L1
3- extrude all objects to the height of 1um
4- make layer L2 the active layer (isolate, etc)
2- select everything on layer L2
3- extrude all objects on layer L2 to the height of 2um
and so on
I know i can do it with Qselect or by using the filter pop-up toolbox. But how would you do it in a script?
thanks
hmsilva
@Anonymous wrote:
Hi all
and so on
thanks
Hello ehsanshahos and welcome to the Autodesk Community!
By 'in a script' do you mean a '*.scr' file or a '*.lsp' file?
If a '*.lsp' file, perhaps something like this will do the trick.
Quick and dirty and untested...
(vl-load-com)
(defun c:demo (/ laylst ss tblname)
   (while (setq tblname (tblnext "Layer" (null tblname)))
      (setq laylst (cons (strcase (cdr (assoc 2 tblname))) laylst))
   (command "_.Layer" "_T" "*" "_ON" "*" "_U" "*" "")
   (foreach lay laylst
      (if (and (wcmatch lay "L#*")
               (setq ss (ssget "_X" (list '(0 . "LWPOLYLINE") (cons 8 lay) (cons 410 (getvar 'ctab)) '(-4 . "&=") '(70 . 1))))
         (command "_.Layer" "_S" lay "" "_.extrude" ss "" (read (vl-string-subst "" "L" lay)))
   (princ)
Hope this helps,
Henrique
