SuperFlatten 2.0c Error Message not working!
Code_x
Message 1 of 8
Code_x
It's been a while since I got this superflatten LSP, and for some reason, it stopped working. Whenever I open any file and run the command, it gives me the error message below. Can someone tell me what the issue is, or if there is an updated version of superflatten LSP that works with AutoCAD 2024? Can you please share if you have it available. Thank you!
Error: no function definition: VLAX-ENAME->VLA-OBJECT
Replies (7)
Message 2 of 8
Kent1Cooper
A line like this:
(vl-load-com)
in the AutoLisp file should prevent that error.  Is there such a line?
If not, first try typing that in at the Command: prompt yourself, then run the command.  If it works, we can get into where it should be added in the file.
Kent Cooper, AIA
Message 3 of 8
Code_x
I didn't help, still the same error..
Message 4 of 8
Kent1Cooper
The links I find are all to the Swamp, where I am not a member.  If it's un-copyrighted freeware, can you post the AutoLisp file?
Or, try an alternative such as @john.uhden 's SQUASH command, >here<.
Kent Cooper, AIA
Message 5 of 8
paullimapa
Do you get an error when you copy & paste this line and press enter at the command prompt:
(vlax-ename->vla-object (car(entsel)))
Paul Li
IT Specialist
@The Office
Message 6 of 8
paullimapa
do you get this far in running it?
Share a screenshot of your commandline
Paul Li
IT Specialist
@The Office
Message 7 of 8
Code_x
No, I don’t. I entered the command you posted here, and it asked me to select an object. When I did, it gave me the error shown below.
Select object: ; error: no function definition: VLAX-ENAME->VLA-OBJECT
Message 8 of 8
paullimapa
So you’re definitely missing the vl library functions. Perhaps try resetting AutoCAD
Paul Li
IT Specialist
@The Office
