Visual LISP, AutoLISP and General Customization
AutoCAD 2022: A lisp file that can identify hatches that fail to have “cumulative area”,
9 REPLIES 9
Message 1 of 10
JamaL9722060
604 Views, 9 Replies
For example, in the screenshot below, some of the hatches fail to have accumulative. I would appreciate if experts can share a lisp file that can identify these hatches
Thank you
Jamal Numan
9 REPLIES 9
Message 2 of 10
john.uhden
in reply to: JamaL9722060
@JamaL9722060
When hatches have boundaries that touch (and maybe overlap) themsleves, AutoCAD fails to compute an area, so it doesn't provide an area property.  I could write a routine that highlights (selects) any hatch of such condition, but I don't have a newer release at home and have responsibilities at work.  Someone here will surely jump in to help you out.
Meanwhile, just grip a suspected hatch and see if an area shows up in its properties display.  Maybe you will notice the interference and can just grip/move a vertex over a little.  It doesn't need to be associative, in fact it's better if not IMHO.
John F. Uhden
Message 3 of 10
hosneyalaa
Hi , please Attached example drawing
Message 4 of 10
JamaL9722060
I would appreciate if you could share the lisp file. It appears that it’s not attached
Thank you
Jamal Numan
Message 5 of 10
hosneyalaa
HI
TRY
(Defun c:TESST ( / ALIST AREA_ E HTCH I INT_POINT SS TS VEXS)
  (vl-load-com)
  (if
    (setq ss (ssget '((0 . "Hatch"))))
    (progn
      (repeat (setq i (sslength ss))
	(setq e (vlax-ename->vla-object (setq htch(ssname ss (Setq i (1- i))))))
	(setq alist (entget htch))
	(if alist
	  (progn
	    (setq vexs (reverse (cdr
				  (reverse (cdr
					     (mapcar 'cdr (vl-remove-if-not
							    (function (lambda (x)(= (car x) 10)))
							    alist)))))))
	(IF
	  (not
	    (vl-catch-all-error-p
	      (setq area_ (vl-catch-all-apply 'vla-get-area (list E)))
	  (progn (entmakex (list (cons 0 "TEXT")
				 (cons 10  (car vexs))
				 (cons 40 (* 4 (setq ts(getvar "textsize"))))
				 (cons 41 1)
				 (cons 1  (RTOS area_ 2 2 )))))
				 (cons 41 1)
				 (cons 1  "CHECK_AREA "))))
	);;repeat
  (princ)
Message 6 of 10
john.uhden
@JamaL9722060
Try this.  It won't fix anything, but will report and show you any bad hatches in Modelspace.
(defun c:badhatch ( / *error* vars vals ss i e obj area bad n)
  ;; John F. Uhden, Sea Girt, NJ, USA
  ;; Program finds and selects with cold grips
  ;; all hatches that have no area
  ;; v1.0 (3-30-22)
  (gc)
  (vl-load-com)
  (princ "\nBADHATCH v1.0 (c)2022, John F. Uhden")
  (defun *error* (error)
    (mapcar 'setvar vars vals)
    (vla-endundomark *doc*)
    (cond
      ((not error))
      ((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
      (1 (princ (strcat "\nERROR: " error)))
    (princ)
  (setq vars '(cmdecho))
  (setq vals (mapcar 'getvar vars))
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (vla-startundomark *doc*)
  (mapcar 'setvar vars '(0))
  (command "_.expert" (getvar "expert")) ;; dummy command
  (if (setq ss (ssget "x" '((0 . "hatch")(410 . "Model"))))
    (progn
      (setq bad (ssadd))
        (setq e (ssname ss (setq i (1- i))))
        (setq obj (vlax-ename->vla-object e))
        (setq area (vl-catch-all-apply 'vlax-get (list obj 'area)))
        (if (vl-catch-all-error-p area)
          (ssadd e bad)
      (if (> (setq n (sslength bad)) 0)
        (progn
          (sssetfirst nil bad)
          (alert (strcat "Found " (itoa n) " bad hatch(es)."))
        (prompt "\nFound no bad hatches.")
    (prompt "\nThere are no hatch objects in ModelSpace.")
  (*error* nil)
John F. Uhden
Message 7 of 10
JamaL9722060
Both works fine for me. Thank you very much for the help
Jamal Numan
Message 8 of 10
JamaL9722060
I would appreciate John if you could further develop the lisp file so that one can select which portion of the drawing one needs to identify the hatches with no cumulative areas
For example, in the file attached, the machines gets sluggish after applying the command
Jamal Numan
Message 9 of 10
john.uhden
@JamaL9722060
Just change
to
(if (setq ss (ssget '((0 . "hatch"))))
John F. Uhden
Message 10 of 10
JamaL9722060
It works fine. Thank you for the prompt help and time
Jamal Numan
AutoCAD Inside the Factory
