Sum of dynamic block attributes and Text or MText with above a line and update the Value with Selection
skchui6159
Message 1 of 30
skchui6159
Is possible on lisp to sum up the value and self update the MText of the no. of rebar of the dynamic block in above a line with selection? If there are no MText, no need to update.
Replies (29)
Message 21 of 30
skchui6159
Sorry, i am apologize that I got the wrong way to do this task.😔 I need to try to modify the block can measure multiple distance and resulting the rebar numbers. Thanks for your advice!
Message 22 of 30
ec-cad
Count.lsp will work for a single set of either Vertical or Horizontal items.
Whatever is included in the 'Crossing' of the 2 points you pick will be copied in the
Horizontal direction. It adjusts the target points, based on original X,Y of each point chosen.
So, if the original info is oriented Horizontal - you get a copy that's Horizontal, and if the
original info is oriented Vertical - you get a copy that's Vertical.
You can include any 'lines' or points, circles, whatever is in the Crossing Window picks.
The program just makes a copy to the right, explodes items if they are 'Inserts,' (Blocks) leaves the
rest as it is. Exploding those Blocks, surfaces the embedded MTEXT's so they can be examined.
Then, the program changes the Properties of those items to be on Layer Temp. Next, it gathers
only the MTEXT items  on Layer Temp, gets their text value, looks for a "(", and gets the numbers inside
the ( ), makes a sum of the (atoi value), string to integer. Once done with that, just removes the
items from the Temp layer, and zooms previous so you can pick the MTEXT item to update.
So, bottom line, should work for either Vert or Horiz.
ECCAD
Message 23 of 30
ec-cad
For this sample drawing. You have the Vertical samples (to the right) of the Horizontal samples.
Since the Lisp has a 'constant' distance to the right that it copies to, you may need to increase
the distance to say, 32000 rather than the 16000 presently.
Try this on your new sample drawing with both Vertical and Horizontal layouts.
ECCAD
Message 24 of 30
Sea-Haven
@ec-cad "increase the distance" use (getvar 'extmax) then add a X or Y value to max, then you know that point so do the edits then copy back, have used this for this type of task. The copied objects will be outside the extmax.
Message 25 of 30
skchui6159
Thank you very much! The lisp works great on vertical and horizontal item!
Message 26 of 30
ec-cad
Sea-Haven,
Great idea. Here's the resultant lisp with (extmax).
ECCAD
Message 27 of 30
Sea-Haven
Happy to help.
This may be the path to a solution, bit busy at moment its Christmas. A pick pick pick answer.
(defun c:wow ( / obj1 obj2 str txt)
(setq obj1 (vlax-ename->vla-object (car (nentsel "\nPick source text "))))
(setq obj2 (vlax-ename->vla-object (car (entsel "\nPick destination text "))))
(setq id (vlax-invoke-method (vla-get-Utility  (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString obj1 :vlax-false))
(setq str (strcat "%<\\AcObjProp Object(%<\\_ObjId " id ">%).TextString>%"))
(vlax-put obj2 'textstring str)
(princ)
I have daisy chain attributes summing them to a field, so maybe can get the ID of the bar number. So method would be pick+pick+pick.
Message 28 of 30
skchui6159
@ec-cad @Sea-Haven Thank you very much! I have update the .LSP with "Mtext" and "Text" version. Added Picking mode. Finally will zoom to the designate location.
Message 29 of 30
skchui6159
Good idea, Thank you very much!
Message 30 of 30
skchui6159
This method is good! The running time of your lisp is very fast.
