WBLOCK - EXPORT VERSION CONTROL
formobalaji
formobalaji
IS IT POSIBILE TO CONTROL THE AUTOCADD VERSION OF EXPORTED DXF BY WBLOCK,
IAM SAVING ALL BLOCKS AS INDIVIDUAL DXF IN THE SOURCE FOLDER USING AUTOLISP, NOW MY QUESTION IS "IS IT POSSIBLE TO CONTROL THE VERSION OF DXF, LIKE V2010, V2007"
Moshe-A
@formobalaji ,
how about this?
(command "._saveas")
Moshe
formobalaji
@Moshe-A
is there any way to save as all blocks before exporting them with WBlock
paullimapa
Perhaps try this:
In the Open and Save tab of the Options dialog box, specify the file format in Save As. So you can specify the dxf version you want here. Then see if the Wblock command will now also create the desired dxf file instead of dwg. But when you’re done with creating all the wblocks you’ll need to go back to the Open and Save tab of the Options dialog box and change this back to a dwg file format to Save As
Paul Li
IT Specialist
@The Office
DGCSCAD
There may be a solution in this thread: https://www.cadtutor.net/forum/topic/66011-save-as/
AutoCad 2018 (full)
Win 11 Pro
