Strip formatting from text (not mtext) objects
Netelaana
Message 1 of 9
Netelaana
I have many, many text objects throughout a large drawing with embedded strike-through "%%K" formatting.
The text string looks like some variation of "PROPOSED%%K S%%KLEEVE"
I would like to strip out all such formatting. I have tried using "StripMtext Version 5.0c" lisp, find and replace, etc. with no success.
I also tried converting the text to mtext first  and then running "StripMtext", but it does not remove the "\k" associated with the strike-through once converted to mtext. I feel as if there should be a simple lisp solution for this issue, but I can't put my finger on it.
An ideal solution would be a "find and replace" approach as the text objects are on multiple layouts and embedded in blocks.
Thanks in advance for any pointers!
Replies (8)
Message 2 of 9
paullimapa
If these Texts are not inside blocks then you can try DDTXTS&R.LSP which is included as an added sample routine in my free TextApps:
https://apps.autodesk.com/ACD/en/Detail/Index?id=5878795472985504811&appLang=en&os=Win32_64
After downloading & installing TextApps the sample DDTXTS&R.LSP can be found in the installed folder under your profile:
"C:\Users\your windows login profile\AppData\Roaming\Autodesk\ApplicationPlugins\TextApps.bundle\Contents\Windows\DDTXTS&R.LSP"
Drag & drop DDTXTS&R.LSPinto the dwg then enter DDTXTS&R to run the code.
Enter ALL to select all Text objects
In the Search & Replace Text window that appears search for %%K & replace with nothing:
Paul Li
IT Specialist
@The Office
Message 3 of 9
pbejse
(defun c:StrippedStrikeAll (/ aDoc stringValue)
  (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vlax-for blk	(vla-get-blocks aDoc)
    (eq :vlax-false (vla-get-isXref blk))
	    (vlax-for h	blk
	      (if
		(and (vlax-write-enabled-p h)
		     (eq (vla-get-ObjectName h) "AcDbText")
		     (setq stringValue (Vla-get-Textstring h))
		 (progn
		   (while (vl-string-search "%%K" stringValue)
		     (setq stringValue (Vl-string-subst "" "%%K" stringValue))
		   (vla-put-textstring h stringValue)
  (princ)
May require a regen
HTH
Message 4 of 9
Netelaana
Thank you! Worked wonderfully.
Hours of tedium averted.
Message 5 of 9
paullimapa
FYI I think this line of code has an additional c:
(defun c:c:StrippedStrikeAll (/ aDoc stringValue)
 It should be this
Paul Li
IT Specialist
@The Office
Message 6 of 9
pbejse
Thank you for spotting that @paullimapa
Message 7 of 9
pbejse
Glad it works for you 🙂
Happy to help
Message 8 of 9
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 9 of 9
Kent1Cooper
Since the strike-through coding can use either a lower- or upper-case K, here's a version [also with a different approach] that catches either of those [lightly tested]:
(defun C:UST ; = Un-Strike-Through
  (/ ss n txt str)
  (if (setq ss (ssget "_X" '((0 . "TEXT") (1 . "*[Kk]*"))))
    (repeat (setq n (sslength ss)); then
      (setq
        txt (ssname ss (setq n (1- n)))
        str (getpropertyvalue txt "TextString")
      ); setq
      (while (wcmatch (strcase str) "*%%K*")
        (setpropertyvalue txt "TextString"
          (setq str (vl-string-subst "" "%%k" (vl-string-subst "" "%%K" str)))
        ); set...
      ); while
    ); repeat
  ); if
  (prin1)
It doesn't check all Text, but limits itself to only Text objects that contain such coding, even if with mixed %%K and %%k formats.
Kent Cooper, AIA
