- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have many, many text objects throughout a large drawing with embedded strike-through "%%K" formatting.
The text string looks like some variation of "PROPOSED%%K S%%KLEEVE"
I would like to strip out all such formatting. I have tried using "StripMtext Version 5.0c" lisp, find and replace, etc. with no success.
I also tried converting the text to mtext first and then running "StripMtext", but it does not remove the "\k" associated with the strike-through once converted to mtext. I feel as if there should be a simple lisp solution for this issue, but I can't put my finger on it.
An ideal solution would be a "find and replace" approach as the text objects are on multiple layouts and embedded in blocks.
Thanks in advance for any pointers!
