Step though Attributes to find Certain tags
Hey guys,
I've never had to do this before and I thought it may be simple but alas I need help.
I have a border that has several attributes, I need to step through those attributes and make a list of only the attributes with certain tags.
For instance In the border named Stooges there are attributes name Moe, Bill, Larry, Fred, Curly, Steve etc.
I need to make a list that only contains Moe, Larry and Curly.
How Do I accomplish this?
I've been able to select the border using
(defun c:STOOGE ()
  (setq Border (ssget "_X" (list (cons 0 "insert")(cons 2 "Stooges"))))
 Thanks a Million
devitg
It is not mine, I grab it somewhere
(DEFUN G-ATT-LIST  (ENT-OBJBLK
                    ;;lst
  (IF (= (TYPE ENT-OBJBLK) 'ENAME)
    (SETQ OBJBLK (VLAX-ENAME->VLA-OBJECT ENT-OBJBLK))
    (SETQ OBJBLK ENT-OBJBLK)
  (COND
    ((NOT OBJBLK))
    ((/= (VLA-GET-HASATTRIBUTES OBJBLK) :VLAX-TRUE))
    ((VL-CATCH-ALL-ERROR-P
       (SETQ LST (VL-CATCH-ALL-APPLY
                   'VLAX-SAFEARRAY->LIST
                   (LIST (VLAX-VARIANT-VALUE (VLA-GETATTRIBUTES OBJBLK))))))
     (SETQ LST NIL)
    ) ;_c.cond
  LST
  ) ;_c.defun
It return  the attribute objects
Then you have to look for the tags , and it´s string .
hmsilva
As a starting point...
;; test if Stooges exist in current tab
(if (setq Border (ssget "_X"
                        (list '(0 . "insert")
                              '(2 . "Stooges")
                              ;; has attributes
                              '(66 . 1)
                              ;; only in the current tab
                              (cons 410 (getvar 'CTAB))
   ;; if exists
   (progn
      ;; set 'enm' with INSERT's ename
      (setq enm (ssname Border 0))
      ;; set 'obj' with the ename sored in 'enm' as a VLA object
      (setq obj (vlax-ename->vla-object enm))
      ;; set 'atts' as a list with all attributs as VLA objects
      (setq atts (vlax-invoke obj "GetAttributes"))
      ;; process each attribute
      (foreach att atts
         ;; test if TagString is one we need
         (if (wcmatch (vla-get-tagstring att) "Moe,Larry,Curly")
            ;; if true, store in 'lst' the Tag and the Value
            (setq lst (cons (cons (vla-get-tagstring att) (vla-get-textstring att)) lst))
Hope this helps,
Henrique
That did it! thank you very much.
hmsilva
You’re welcome!
Glad I could help
Henrique
