ssm to sheet attribute
lIJOHNSON69QRH
Message 1 of 12
lIJOHNSON69QRH
I have all my property data entered into SSM and want to know if there is a way to link my attributes in my title block to items in my ssm without having to pick each attribute select field and than select sheetset and than select the sheet and property. seems there should be a way to link these without having to go thought this tedious steps. is there a lisp, vbs that can connect a property to a attribute?
I hope someone has an idea on how to do this efficiently.
Lisa
Replies (11)
Message 2 of 12
pbejse
Lisa
Yes you can do that without lisp by assigning the ssm property data name as a default value of the attribute TAG.
We can help you if you want to pursue this further
Message 3 of 12
lIJOHNSON69QRH
Oh yes please, this sounds just what I need. Let me know when you have time to explain.
Thank you,
Lisa
Message 4 of 12
ronjonp
These are the field code values depending on what you need to input as default in your attributes.
if you are familiar with filter or qselect and have these titleblocks already on multiple tabs in your drawing, you can select them all at one then paste this value in the attribute value need via properties palette. <- I do this all the time
Message 5 of 12
pbejse
Thank you,
Lisa
Sure, aside from what  rperez posted,m which applies to already inserted/existing blocl attributes.
You have to assign the field value on the default tag on the ATTRIBUTE DEFINITION inside the block.
This is specially useful for custom properties.
Hope this helps
Message 6 of 12
lIJOHNSON69QRH
These are all great ideas, but one still has to select each attribute (which has it's own identifier) and than select the correct property in sheets set which has it's (own property/identifier). I'm just not good enough at lisp to know how to make something that will do this.
Right now I control all title block data through a lisp that automatically updates attributes every time I open a drawing, and this works great.
I have just been using sheets set to plot. The problem is our client wants the title block linked, so my goal was to continue to run things the way I have been and link the files before our final cad submittal. I just hate the single select process to linking everything.
You guys have some great ideas, but it looks like you are already doing what I'm doing, single select linking., Thank you so much for the input and sharing ideas.
Message 7 of 12
pbejse
@lIJOHNSON69QRH The suggestion we posted is not a single select linking thingy. AAMOF If you do it right you dont need to select anything.  It is already linked and should automatically update.
You mind posting a drawing sample along with a DST file so I can show you what we mean.
Message 8 of 12
lIJOHNSON69QRH
Here you go,
I inherited these file, so I would love to know how to link these in a timely manner.
Message 9 of 12
pbejse
I did a quick modification of the "381630_TitleBlock_BSL_Attributes" attribute block & link the values with the sheet set.
Here's what you do.
Open the the attached file.  AE36687-SL-124_WithFieldsPlaceholder.dwg
Open another drawing lsited on the sheet set.
Delete and purge the 381630_TitleBlock_BSL_Attributes from the newly opened drawing
Copy the block from that drawing. "381630_TitleBlock_BSL_Attributes" to the previous drawing you just open.
Ideally users would  create a new drawing from sheet set using a template that includes that block.
Try it and tell me how it goes and i'll explain further.
Message 10 of 12
lIJOHNSON69QRH
Hi pbejse,
Yes I see how that works once I copy the attribute block into my sheet template and if I start all new sheets through sheet set and the template file is associated to the sheet set from the start.
I think this issues is a little different as these are existing sheets that I inherited and yes if I replaced the attribute block with the new associates block I still have to copy this into each sheet and select the fields to switch the individual links to the next sheet.
I do not see any way around not having to select a field and switching it to the next sheet.
example: I copy the attribute with the fields linked to sheet 1 and I copy it to sheet 2 it is still linked to sheet 1 until I select it and switch  it to sheet 2
I really do appreciate you mentoring and time, I always love learning best practices., maybe I'm just slow,
and I hope you do know something I don't. so if there is a better next step I may need a little hand holding.
Lisa
Message 11 of 12
pbejse
Hi pbejse,
Yes,
Thats the odd part, You shouldnt have to do that at all.
I would recommend redefining the existing block thru Tool pallettes [Ctrl+3] or Design center [Ctrl+2]
That shoudl not happen if you use the 381630_TitleBlock_BSL_Attributes block inisde the sample drawing attached on the previous post.
Its easy really, once you get the hang of it.
Automate Title Block Data in AutoCAD
BTW: I should add, the OTHER sheets should also be listed of the sheet set.
Hang on, Not that it matterss but are you using multiple tabs ?
Message 12 of 12
lIJOHNSON69QRH
Oh my gosh sometimes all the coffee in the world just does not get the juices flowing. I figured out my mistake, totally my bad. I have it working, and yes it works great when done correctly.
Thank your for your patience and guidance. You rock!
