@lIJOHNSON69QRH wrote:
Hi pbejse,
Yes I see how that works once I copy the attribute block into my sheet template and if I start all new sheets through sheet set and the template file is associated to the sheet set from the start.
Yes,
I think this issues is a little different as these are existing sheets that I inherited and yes if I replaced the attribute block with the new associates block I still have to copy this into each sheet and select the fields to switch the individual links to the next sheet.
I do not see any way around not having to select a field and switching it to the next sheet.
example: I copy the attribute with the fields linked to sheet 1 and I copy it to sheet 2 it is still linked to sheet 1 until I select it and switch it to sheet 2
Thats the odd part, You shouldnt have to do that at all.
I would recommend redefining the existing block thru Tool pallettes [Ctrl+3] or Design center [Ctrl+2]
That shoudl not happen if you use the 381630_TitleBlock_BSL_Attributes block inisde the sample drawing attached on the previous post.
I really do appreciate you mentoring and time, I always love learning best practices., maybe I'm just slow,
and I hope you do know something I don't. so if there is a better next step I may need a little hand holding.
Its easy really, once you get the hang of it.
Automate Title Block Data in AutoCAD
BTW: I should add, the OTHER sheets should also be listed of the sheet set.
Hang on, Not that it matterss but are you using multiple tabs ?
