Visual LISP, AutoLISP and General Customization
ssget (Select diagonal line only )
10 REPLIES 10
Message 1 of 11
boyds86
549 Views, 10 Replies
(defun c:CV ()
(setvar "cmdecho" 0)
(command "undo" "be")
(setq osm (getvar "osmode"))
(setvar "regenmode" 1)
(setvar "osmode" 0)
(if(setq A (ssget "_:L" '((0 . "LINE"))))
(progn
(setq n 0)
(setq B (sslength A))
(while (< n B)
(setq C(ssname A n))
(setq D(entget C))
(setq E(cdr(assoc 10 D)))
(command ".QDIM" C "" E "")
(setq n (+ n 1)))))
(setvar "cmdecho" 1)
(setvar "osmode" osm)
(command "undo" "end")
(princ))
I am trying to create a lisp that call out the chamfer dimension. But I do not know how to choose diagonal line (45°) only (Not Vertical line & Horizontal line). I get stuck in here-->(if(setq A (ssget "_:L" '((0 . "LINE") (choose diagonal line condition))))
Thank you for your time!
10 REPLIES 10
Message 2 of 11
Kent1Cooper
in reply to: boyds86
You can't filter for the angle of Lines in (ssget), since it is not something that is stored in their entity data -- it is only a result from what is stored [the endpoints].
You would need to select Lines, and have their angles checked, keeping those at the angle(s) you want and removing others from the selection.  Since Chamfer doesn't need to have equal setbacks on both sides, it can make corner Lines across orthogonal originals that are not at 45°.  If you really mean those at 45° [in any of the 4 directions] only, resulting from equal-setback Chamfers on orthogonal original Lines, the method would be to check that the absolute value of the difference in X coordinates from the start to the end is the same as the difference in Y coordinates [within some tolerance].
Do you ever use unequal-setback Chamfers?  It would be easy enough to find all Lines among a selection that are not orthogonal, that is, in which neither the X or Y difference between ends is zero, but would that get what you want?
Do you want Chamfered-corner Lines between Lines that are not orthogonal?  Those would be very difficult, if even possible, for a routine to identify.  What about between original Lines that are not perpendicular to each other?
Kent Cooper, AIA
Message 3 of 11
Sea-Haven
Like Kent if you have a pline with the chamfer as part of the pline you can pick it and get segment and the 2 vertice points, like wise though could walk through a pline looking at segment angle.
If happy to do pick, pick,pick can look at line or pline and do dimension.
Message 4 of 11
boyds86
in reply to: Kent1Cooper
It is not necessary to use the ssget, I want to choose all the diagonal lines (Exactly 45° ) for one time by choose an area i want to dimension. Then I use Qdim to dimension them.
Message 5 of 11
Kent1Cooper
@boyds86 wrote:
.... I want to choose all the diagonal lines (Exactly 45° ) ....
One way you can try:
(setq D (entget C))
(setq
  E (cdr (assoc 10 D))
  F (cdr (assoc 11 D))
  delta (mapcar '- F E); difference start to end
); setq
(if (equal (abs (car delta)) (abs (cadr delta)) 0.01); at some 45° direction in XY
  (command ".QDIM" C "" E ""); then
); if
(setq n (+ n 1)))))
You can adjust the 0.01 fuzz factor for how exactly at 45° a Line is, if needed.
Kent Cooper, AIA
Message 6 of 11
devitg
@boyds86
Would it always be the figure as shown , say large sides vertical or horizontal?
and chamfer only 45 , 135 , 225 , 315 degree  , or 0.25 pi , 0.75 pi , 1.25 pi or 1.75 pi ?
If possible , upload a real dwg .
Message 7 of 11
Kent1Cooper
An angle-based [rather than XY-difference-based] approach:
(setq D (entget C))
(setq
); setq
(if (equal (rem (angle E F) (/ pi 2)) (/ pi 4) 0.001); at some 45° direction
); if
(setq n (+ n 1)))))
Kent Cooper, AIA
Message 8 of 11
Sea-Haven
The other way maybe for unequal length chamfer  but still dim them and may work rotated as well would be get bounding box use  a length factor less than 25% of min ht wid, A real dwg would be good are they lines easy plines a bit harder.
Message 9 of 11
boyds86
Thank you very much. This is the one I Need!
Message 10 of 11
boyds86
in reply to: devitg
Thank you for your concern! @Kent1Cooper has helped me!
Message 11 of 11
boyds86
in reply to: Sea-Haven
Thank you for your concern! It is solved by @Kent1Cooper
Forma Design Contest
AutoCAD Beta
