Sprinkler network Pipe Sizing
hi all,
when using this lisp with this file there is sum problems:
1-it can't recognize the main pipe.
2-text height for pipe size is 15 but i work with 200.
3-text layer is the same for the pipe.
4-text is without leader with is just a line on another layer
note that:
*Text Layer "FIRE-TEXT-P"
*Branch layer "FIRE-PIPE-P"
*Main Layer "FIRE-Main-P"
(vl-load-com) (defun C:PipesDia (/ *error* _SortPtListByDist _plDirCheck _ssFilter _getDia oVAR doc ss sspl ssm ensel en p i l pts ptm ptsa ptsm ptsmr skip pt1dist pt2dist) ;------ (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg))) (if sspts (repeat (sslength sspts) (entdel (ssname sspts 0)) (ssdel (ssname sspts 0) sspts))) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ)) ;Modified. Orig By BlackBox, http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance (defun _SortPtListByDist (ptList en lst) (mapcar (function (lambda (x / ptList2) (if lst (setq ptList2 (car (cons (cdar x) ptList2))) (setq ptList2 (append (cdar x) ptList2))))) (vl-sort (mapcar (function (lambda (x / pt ptlist2) (setq ptlist2 (cons (cons (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (if lst (car x) x) T)) x) ptlist2)))) ptList) (function (lambda (x y) (< (caar x) (caar y))))))) ;------ (defun _plDirCheck (ss / i en enl enr sspt) (setq sspt (ssadd)) (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i)))) (setq enl (entlast)) (command "_.POINT" (vlax-curve-getPointAtDist en (if (< 50 (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))) 20 0))) (if (/= enl (entlast)) (ssadd (entlast) sspt))) (initget "Quit") (setq ensel (entsel "\nDirections of polylines are OK? No, select one to reverse [Quit] <OK>: ")) (cond ((eq ensel "Quit") ;Quit, leave with nil (command "_.ERASE" sspt "")) ((not ensel) ;OK, leave with T (command "_.ERASE" sspt "") T) ((wcmatch (cdr (assoc 0 (entget (setq enr (car ensel))))) "LWPOLYLINE,LINE") ;Reverse, go again (command "_.REVERSE" enr "") (princ "\nPolyline was reversed.") (command "_.ERASE" sspt "") (setq sspt nil) (_PLDirCheck ss)) (T ;Wrong selection go again (command "_.ERASE" sspt "") (setq sspt nil) (_PLDirCheck ss)))) ;------ (defun _ssFilter (ss code flt / ssn) (setq ssn (ssadd) i (sslength ss)) (while (not (minusp (setq i (1- i)))) (if (wcmatch (cdr (assoc code (entget (ssname ss i)))) flt) (ssadd (ssname ss i) ssn))) ssn) ;------ (defun _getDia (i / ) (cond ((<= i 2) "25 mm") ((<= i 3) "32 mm") ((<= i 5) "40 mm") ((<= i 10) "50 mm") ((<= i 20) "65 mm") ((<= i 40) "80 mm") ((<= i 100) "100 mm") ((<= i 275) "150 mm") (T "%%c"))) ;------------------------------------------------------------------------------------------------------ ;------------------------------------------------------------------------------------------------------ (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (foreach e '(CMDECHO OSMODE ORTHOMODE PDMODE CLAYER CECOLOR LUNITS) (setq oVAR (cons (cons e (getvar e)) oVAR))) (setvar 'CMDECHO 0) (setvar 'ORTHOMODE 0) (setvar 'OSMODE 0) (setvar 'PDMODE 3) (setvar 'LUNITS 4) (if (and (princ "\nNeed Blocks and (Poly)lines, ") (setq ss (ssget "_:L" '((0 . "INSERT,LWPOLYLINE,LINE")))) (setq sspl (ssget "_P" '((0 . "LWPOLYLINE,LINE")))) ;filter origin ss for PL/Lines only (setq p (sslength sspl)) (> p 0) (setq ss (_ssFilter ss 0 "INSERT")) ;filter origin ss for Block only (setq i (sslength ss)) (> i 1) (not (command "_.-LAYER" "_M" "Pipe Dia" "_C" 170 "" "")) (setvar 'CECOLOR "2") (_plDirCheck sspl) (setvar 'CECOLOR (cdr (assoc 'CECOLOR oVAR))) (while (not (minusp (setq i (1- i)))) (setq ptsa (cons (cdr (assoc 10 (entget (ssname ss i)))) ptsa))) ;make a list of blocks ins points (setq ssm (ssadd)) ) (progn (while (not (minusp (setq p (1- p)))) ;for all polylines (setq en (ssname sspl p) pts nil) (if (and (foreach e ptsa ;enclose blocks to its polylines (less 10) (if (> 10 (distance e (setq pt (vlax-curve-getClosestPointTo en e)))) (setq pts (cons pt pts)) T)) (if pts (setq pts (_SortPtListByDist pts en nil)) ;sort by dist (progn (ssadd en ssm) ;ss for main pipe nil)) (setq ptsm (cons (cons (vlax-curve-getEndPoint en) (length pts)) ptsm)) ;make pairs of (pt end of pipe + numb. of blocks) for main pipe (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) ;add last point of pipe without a block (vlax-curve-getDistAtPoint en (last pts))) 10) (setq pts (append pts (list (vlax-curve-getEndPoint en)))) T) (setq i 0) ) (repeat (1- (length pts)) ;mark diameters of all but main pipe. (setq pt1dist (vlax-curve-getDistAtPoint en (nth i pts)) pt2dist (vlax-curve-getDistAtPoint en (nth (1+ i) pts)) ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2))) ;middle point txt (_getDia (1+ i)) i (1+ i)) (command "_.TEXT" ptm "1\'3\"" "" txt)))) (if (and (cond ((= (sslength ssm) 1) ;if only pipe left, take it as MAIN PIPE (setq en (ssname ssm 0))) (T (and (setq ensel (entsel "\nSelect the MAIN PIPE <quit>: ")) ;select new if more then 1 or none (setq en (car ensel)) (wcmatch (cdr (assoc 0 (entget en))) "LWPOLYLINE,LINE")))) (> (length ptsm) 1) (setq ptsm (_SortPtListByDist ptsm en 0)) ;sort by dist (setq i 0 skip 0) (repeat (1- (length ptsm)) ;if pipes at across each other (less 5) (if (< (- (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsm)))) (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsm))))) 5) (setq skip (+ skip (cdr (nth i ptsm)))) ;count block of skipped pipes (setq ptsmr (cons (cons (car (nth i ptsm)) ;created REVERED list!! (was already sorted) (+ skip (cdr (nth i ptsm)))) ptsmr) skip 0)) (setq i (1+ i))) (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) ;add last part exceeding (more 10) (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (last ptsmr))))) 10) (setq ptsmr (cons (cons (vlax-curve-getEndPoint en) 0) ptsmr)) T) (setq i 0 l 0 ptsmr (reverse ptsmr)) ;list REVERSE back. ) (repeat (1- (length ptsmr)) ;mark diameters of main pipe (setq pt1dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsmr)))) pt2dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsmr)))) ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2))) l (+ l (cdr (nth i ptsmr))) txt (_getDia l) i (1+ i)) (command "_.TEXT" ptm "1\'3\"" "" txt)))) (princ "\nTerminated by user or by error: Wrong selection, need at least 2 BLOCKs and 1 (POLY)LINE.")) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ) )
