Lisp to place pipe dia
tanvirme2k9
Message 1 of 35
tanvirme2k9
Hi all,
I am interested in a lisp that will insert pipe diameter. The pipe is just a line or polyline. Blocks are placed on the pipe at different distances. The pipe dia will be placed in between two blocks with a dia symbol according to the following rule –
The number of block       Dia
<=2                                 1”
2< No. of blocks <=3       1.25”
3< No. of blocks <=5       1.5”
5< No. of blocks <=10     2”
For better understand please see the attached file. Thanks in advance.
Replies (34)
Message 2 of 35
ВeekeeCZ
Hi tanvirme, welcome to this forums.
Try this code.
Spoiler
(vl-load-com)
(defun C:PipeDia (/ *error* _SortPtListByDist oCMDECHO oOSMODE doc ss ensel en i pt1 pt2 ptm pts pt1dist pt2dist  txt)
 (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'CMDECHO oCMDECHO)
    (setvar 'OSMODE oOSMODE)
    (vla-endundomark doc)
    (princ))
 (defun _SortPtListByDist  (ptList en)
  ;; Argument: Point list
  ;; Returns: Point list, sorted by distance from curve
  ;; By BlackBox
  ;; http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
  (mapcar
    '(lambda (x / ptList2)
       (setq ptList2 (append (cdr x) ptList2)))
    (vl-sort
      (mapcar
        '(lambda (x / pt ptlist2)
           (setq ptlist2
                  (append
                    (cons
                      (vlax-curve-getDistAtPoint
			(ssname sspl 0)
			(vlax-curve-getClosestPointTo en x T))
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
         (< (car x) (car y))))))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (setq oCMDECHO (getvar 'CMDECHO)
  	oOSMODE	 (getvar 'OSMODE))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
  (if (and (princ "\nNeed BLOCKs, ")
	   (setq ss (ssget '((0 . "INSERT"))))
	   (< 2 (setq i (sslength ss)))
	   (setq ensel (entsel "\nSelect a (poly)line closer to beginning: "))
	   (wcmatch (cdr (assoc 0 (entget (setq en (car ensel))))) "LWPOLYLINE,LINE")
	   (if (> (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (cadr ensel)))
		  (/ (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 2))
	     (progn
	       (command "_.REVERSE" en "")
	       (princ "\nPolyline was reversed.")
	       (setq en (entlast)))
	     T)
	   (while (not (minusp (setq i (1- i))))
	     (setq pts (cons (vlax-curve-getClosestPointTo en (cdr (assoc 10 (entget (ssname ss i))))) pts)))
	   (setq pts (_SortPtListByDist pts en))
	   (setq i 0))
    (repeat (1- (length pts))
      (setq pt1 (nth i pts)
	    pt1dist (vlax-curve-getDistAtPoint en pt1)
	    pt2 (nth (1+ i) pts)
	    pt2dist (vlax-curve-getDistAtPoint en pt2)
	    ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2))))
      (cond ((< i 2) (setq txt "%%c1\""))
	    ((< i 3) (setq txt "%%c1.25\""))
	    ((< i 5) (setq txt "%%c1.5\""))
	    ((< i 10) (setq txt "%%c2\""))
	    (T (setq txt "%%c")))
      (command "_.TEXT" ptm 1 "" txt) 						;<- Here change a text hight
      (setq i (1+ i)))
    (princ "\nWrong selection, need BLOCKs."))
  (princ)
The code presupposes that you have a single line or polyline (you need to join them). If you have it in reverse, program reverse it automatically.
BTW. Your drawing doesn't meet the conditions you gave (second 1.25 should be 1.5).
Question to some college who uses an imperial units: What is a correct format of this number  (command "_.TEXT" 1'-3"1 "" txt). Thanks in advance.
Message 3 of 35
tanvirme2k9
Oops! sorry, right the second 1.25" will be 1.5". I have found this error executing the command -
Object direction has been reversed.
Error: bad argument value: AcDbCurve 43
and sometimes -
Error: bad argument type: lselsetp nil
Message 4 of 35
ВeekeeCZ
Try this...
Spoiler
(vl-load-com)
    (princ))
  ;; By BlackBox
  (mapcar
    (vl-sort
      (mapcar
           (setq ptlist2
                  (append
                    (cons
			(ssname sspl 0)
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
	     (progn
	       (princ "\nPolyline was reversed."))
	     T)
	   (setq i 0))
      (command "_.TEXT" ptm "1\'3\"" "" txt) 	;<- Here change a text hight
      (setq i (1+ i)))
  (princ)
Message 5 of 35
tanvirme2k9
Same
Message 6 of 35
ВeekeeCZ
You know, since I don't get such an error it's hard to tell...
Try again...
Spoiler
(vl-load-com)
    (princ))
  ;; By BlackBox
  (mapcar
    (vl-sort
      (mapcar
           (setq ptlist2
                  (append
                    (cons
			(ssname sspl 0)
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
	   (if (> (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (cadr ensel) T))
	     (progn
	     T)
	     (setq pts (cons (vlax-curve-getClosestPointTo en (cdr (assoc 10 (entget (ssname ss i)))) T) pts)))
	   (setq i 0))
      (setq i (1+ i)))
  (princ)
If the error persist, post the dwg and try find what line is causing that.
Use VLIDE command in autocad, in editor open youre pipedia.lsp. Then in Menu Debug / mark Break on Error. Then load pipedia with Ctrl+Alt+E. Then activate Autocad with Window/Activate Autocad and then run command PIPEDIA. If you get an error, find a line with Ctrl+F9 in Editor.
Message 7 of 35
tanvirme2k9
Thanks for reply. I followed the procedure and it stops at the following line.
(ssname sspl 0)
Message 8 of 35
ВeekeeCZ
I see, it should be en.
Spoiler
(vl-load-com)
    (princ))
  ;; By BlackBox
  (mapcar
    (vl-sort
      (mapcar
           (setq ptlist2
                  (append
                    (cons
			en
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
	     (progn
	     T)
	   (setq i 0))
      (setq i (1+ i)))
  (princ)
Message 9 of 35
tanvirme2k9
Great! worked like a magic. Loving the community! It will save a lot of time, thank you so much. I am wondering if it is possible to do the same thing for the entire piping system (I am new, so I didn't post it first as I don't know whether it is possible) with the following rule -
<=2                                       1”
10< No. of blocks <=20         2.25”
20< No. of blocks <=40         3”
40< No. of blocks <=100       4”
100< No. of blocks <=275     6”
 and also dimensioning it. I appolize that it may be an inappropriate question. Again Thank you very much..
Message 10 of 35
ВeekeeCZ
It's no problem... expending a range.
Spoiler
(vl-load-com)
    (princ))
  ;; By BlackBox
  (mapcar
    (vl-sort
      (mapcar
           (setq ptlist2
                  (append
                    (cons
			en
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
	     (progn
	     T)
	   (setq i 0))
	    ((< i 20) (setq txt "%%c2.25\""))
	    ((< i 40) (setq txt "%%c3\""))
	    ((< i 100) (setq txt "%%c4\""))
	    ((< i 275) (setq txt "%%c6\""))
      (setq i (1+ i)))
  (princ)
Dimensioning I'll do next time. But it would be quite similar... I tried find some "block dimensioning" on web and I'm surprised I couldn't find some...
Message 11 of 35
tanvirme2k9
Actually I wanted to place all the diameter one at time, may be it's not possible.
Message 12 of 35
tanvirme2k9
I was working with the previous 'pipedia', I found that I need a little modification like the image. Can you please modify a bit? Thanks in advance.
Message 13 of 35
ВeekeeCZ
Ok, see the code below. Also added a layer handling, now it is placing the texts into correct layer (blue Pipe Dia)
Spoiler
(vl-load-com)
(defun C:PipeDia (/ *error* _SortPtListByDist oCMDECHO oOSMODE oCLAYER doc
	            ss ensel en len i pt1 pt2 ptm pts pt1dist pt2dist txt)
    (setvar 'CLAYER oCLAYER)
    (princ))
;By BlackBox, http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
  (mapcar
    (vl-sort
      (mapcar
           (setq ptlist2
                  (append
                    (cons
			en
                      x)
                    ptlist2)))
        ptList)
      '(lambda (x y)
	oCLAYER	 (getvar 'CLAYER))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
	   (< 1 (setq i (sslength ss)))
		  (/ (setq len (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))) 2))
	     (progn
	     T)
	   (if (> (- len (vlax-curve-getDistAtPoint en (last pts))) 10)
	     (setq pts (append pts (list (vlax-curve-getEndPoint en))))
	     T)
	   (not (command "_.-LAYER" "_M" "Pipe Dia" "_C" 170 "" ""))
	   (setq i 0)
      (setq i (1+ i)))
  (princ)
Message 14 of 35
tanvirme2k9
Great!! Thank you man!
Message 15 of 35
ВeekeeCZ
@tanvirme2k9 wrote:
... I am wondering if it is possible to do the same thing for the entire piping system ...
Yes, it can. Well, almost, with some restrictions and requirements - look at the attachment, adjusted dwg:
- Each tube has its single line or polyline in the right direction (your previous drawing contained one line for opposite tubes with opposite flow - is not possible). For a multiple break you can use one of the CABs routines - very nice.
http://www.theswamp.org/index.php?topic=10370.0
Spoiler
It requires to be registered, but it's worth it.
- Blocks are assigned the its curve based on distances (less than 10 inches). Blocks must be inserted with sufficient accuracy.
- The cross main pipe can not be labeled - you can include this (poly)line in a selection, but it has no blocks closer than 10 inches, would not labeled)
- Selection function is properly filtered  - when selecting a window can be applied to the entire system objects, other than blocks, lines and polylines will be excluded)
- When selected, you can check the direction of the curves (marked with points at beginnings), you cat manually select the one with wrong direction a reverse it.
- You cad try what can be done and what not - but it is not bulletproof 🙂
Spoiler
(vl-load-com)
(defun C:PipesDia (/ *error* _SortPtListByDist _plDirCheck _ssFilter oVAR doc
	             ss sspl ensel en p i ptm pts ptsa pt1dist pt2dist txt)
   (if sspts (repeat (sslength sspts)
	       (entdel (ssname sspts 0))
	       (ssdel (ssname sspts 0) sspts)))
    (foreach e oVAR (setvar (car e) (cdr e)))
    (princ))
  (mapcar
    (vl-sort (mapcar '(lambda (x / pt ptlist2)
			(setq ptlist2 (append (cons (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en x T))
						    x)
					      ptlist2)))
		     ptList)
	     '(lambda (x y)
  (defun _plDirCheck (ss / i en enl enr sspt)
    (setq sspt (ssadd))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i))))
      (if (< 50 (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
	(progn
	  (setq enl (entlast))
	  (command "_.POINT" (vlax-curve-getPointAtDist en 20))
	  (if (/= enl (entlast))
	    (ssadd (entlast) sspt)))))
    (initget "Quit")
    (setq ensel (entsel "\nDirections of polylines are OK? No, select one to reverse [Quit] <OK>: "))
    (cond ((eq ensel "Quit")								;Quit, leave with nil
	   (command "_.ERASE" sspt ""))
	  ((not ensel)									;OK, leave with T
	   T)
	  ((wcmatch (cdr (assoc 0 (entget (setq enr (car ensel))))) "LWPOLYLINE,LINE") 	;Reverse, go again
	   (command "_.REVERSE" enr "")
	   (setq sspt nil)
	   (_PLDirCheck ss))
	  (T 										;Wrong selection go again
	   (setq sspt nil)
	   (_PLDirCheck ss))))
  (defun _ssFilter (ss code flt / ssn)
    (setq ssn (ssadd)
	  i (sslength ss))
      (if (wcmatch (cdr (assoc code (entget (ssname ss i)))) flt)
	(ssadd (ssname ss i) ssn)))
    ssn)
  (foreach e '(CMDECHO OSMODE ORTHOMODE PDMODE CLAYER CECOLOR)
    (setq oVAR (cons (cons e (getvar e)) oVAR)))
  (setvar 'CMDECHO 0)
  (setvar 'ORTHOMODE 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (if (and (princ "\nNeed Blocks and (Poly)lines, ")
	   (setq ss (ssget '((0 . "INSERT,LWPOLYLINE,LINE"))))
	   (setq sspl (ssget "_P" '((0 . "LWPOLYLINE,LINE"))))
	   (setq p (sslength sspl))
	   (> p 1)
	   (setq ss (_ssFilter ss 0 "INSERT"))
	   (> i 0)
	   (not (command "_.-LAYER" "_M" "0" ""))
	   (setvar 'CECOLOR "2")
	   (_plDirCheck sspl)
	   (setvar 'CECOLOR (cdr (assoc 'CECOLOR oVAR)))
	     (setq ptsa (cons (cdr (assoc 10 (entget (ssname ss i)))) ptsa)))
    (while (not (minusp (setq p (1- p))))
      (setq en (ssname sspl p)
	    pts nil)
      (if (and (foreach e ptsa
		 (if (> 10 (distance e (setq pt (vlax-curve-getClosestPointTo en e))))
		   (setq pts (cons pt pts))
		   T))
	       (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))
		      10)
		 T)
	       (setq i 0)
	  (setq pt1dist (vlax-curve-getDistAtPoint en (nth i pts))
		pt2dist (vlax-curve-getDistAtPoint en (nth (1+ i) pts))
		txt (cond ((< i 2)   "%%c1\"")
			  ((< i 3)   "%%c1.25\"")
			  ((< i 5)   "%%c1.5\"")
			  ((< i 10)  "%%c2\"")
			  ((< i 20)  "%%c2.25\"")
			  ((< i 40)  "%%c3\"")
			  ((< i 100) "%%c4\"")
			  ((< i 275) "%%c6\"")
			  (T         "%%c"))
		i (1+ i))
	  (command "_.TEXT" ptm "1\'3\"" "" txt))))
    (princ "\nWrong selection, need at least 2 BLOCKs and 1 (POLY)LINE."))
  (princ)
@tanvirme2k9 wrote:
... and also dimensioning it. ...
This task is for a separate routine. So make a new thread on this topic. This principle of making dims between blocks can be generally used... Maybe someone comes up with nice and simple solution. If not, i'll make it later.
Message 16 of 35
tanvirme2k9
I can't believe my eyes!! Thanks a lot.....
Message 17 of 35
ВeekeeCZ
I figured this out on my way to work... It would be a separated routine... calculation would use the latest texts (dia labels) of each tube. So I need the formula to calculate diameters of main tube.
Message 18 of 35
tanvirme2k9
Thanks for your effort. It will be same as the previous one i.e
The number of blocks         Dia
<=2                                     1”
and the main pipe can be started from any side - left/right or up/down. Please find the attached drawing as reference.
Message 19 of 35
ВeekeeCZ
<=2                                     1”
 10< No. of blocks <=20       2.25” <<<  Should this be 2.5?
Message 20 of 35
ВeekeeCZ
I addeed this feature as well. And made some corrections....
- you can select your main pipe as well (as part of main selection).
- if only one polyline left (all others has blocks close or on..) - this one will be recognize as main pipe automatically. It there is none or more then one, you will be asked for selection
- in first part of routine where you can check and reverse direction... I made a little change - If is the line long enought (>50) is the mark point made at distance of 20, in other cases (< 50) is made in its beginning point (some lines has length of 0)
Spoiler
(vl-load-com)
(defun C:PipesDia (/ *error* _SortPtListByDist _plDirCheck _ssFilter _getDia oVAR doc
	             ss sspl ssm ensel en p i l pts ptm ptsa ptsm ptsmr skip pt1dist pt2dist)
    (princ))
;Modified. Orig By BlackBox, http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
 (defun _SortPtListByDist  (ptList en lst)
  (mapcar
    (function (lambda (x / ptList2)
		(if lst
		  (setq ptList2 (car (cons (cdar x) ptList2)))
		  (setq ptList2 (append (cdar x) ptList2)))))
    (vl-sort (mapcar
	       (function (lambda (x / pt ptlist2)
			   (setq ptlist2 (cons (cons (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (if lst (car x) x) T))
						      x)
						 ptlist2))))
	       ptList)
	     (function (lambda (x y)
			 (< (caar x)
			    (caar y)))))))
    (setq sspt (ssadd))
			   en
			     20
			     0)))
    (initget "Quit")
	   T)
	   (setq sspt nil)
	   (_PLDirCheck ss))
	   (setq sspt nil)
	   (_PLDirCheck ss))))
    (setq ssn (ssadd)
	  i (sslength ss))
    ssn)
  (defun _getDia (i / )
	  ((< i 10)  "%%c2\"")
	  ((< i 20)  "%%c2.5\"")
	  ((< i 40)  "%%c3\"")
	  (T         "%%c")))
  (foreach e '(CMDECHO OSMODE ORTHOMODE PDMODE CLAYER CECOLOR LUNITS)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (setvar 'LUNITS 4)
	   (setq sspl (ssget "_P" '((0 . "LWPOLYLINE,LINE"))))					;filter origin ss for PL/Lines only
	   (> p 0)
	   (setq ss (_ssFilter ss 0 "INSERT"))							;filter origin ss for Block only
	   (> i 1)
	   (_plDirCheck sspl)
	     (setq ptsa (cons (cdr (assoc 10 (entget (ssname ss i)))) ptsa)))			;make a list of blocks ins points
	   (setq ssm (ssadd))
    (progn
      (while (not (minusp (setq p (1- p)))) 							;for all polylines
	      pts nil)
        (if (and (foreach e ptsa								;enclose blocks to its polylines (less 10)
		     T))
	         (if pts
		   (setq pts (_SortPtListByDist pts en nil))					;sort by dist
		   (progn
		     (ssadd en ssm)								;ss for main pipe
		     nil))
		 (setq ptsm (cons (cons (vlax-curve-getEndParam en) (length pts)) ptsm))  	;make pairs of (pt end of pipe + numb. of blocks) for main pipe
	         (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 	  	;add last point of pipe without a block
		        10)
		   T)
		 (setq i 0)
	  (repeat (1- (length pts))								;mark diameters of all but main pipe.
		  ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2)))	;middle point
		  txt (_getDia i)
		  i (1+ i))
      (if (and (cond ((= (sslength ssm) 1)							;if only pipe left, take it as MAIN PIPE
		      (setq en (ssname ssm 0)))
		     (T
		      (and (setq ensel (entsel "\nSelect the MAIN PIPE <exit>: "))		;select new if more then 1 or none
			   (wcmatch (cdr (assoc 0 (entget en))) "LWPOLYLINE,LINE"))))
	       (> (length ptsm)  1)
	       (setq ptsm (_SortPtListByDist ptsm en 0))						;sort by dist
	       (setq i 0
		     skip 0)
	       (repeat (1- (length ptsm))										;if pipes at across each other (less 5)
		 (if (< (- (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsm))))
			   (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsm)))))
			5)
		   (setq skip (+ skip (cdr (nth i ptsm)))) 							;count block of skipped pipes
		   (setq ptsmr (cons (cons (car (nth i ptsm))							;created REVERED list!! (was already sorted)
				     ptsmr)
			 skip 0))
		 (setq i (1+ i)))
	       (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))				;add last part exceeding (more 10)
			 (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (last ptsmr)))))
		        10)
		   (setq ptsmr (cons (cons (vlax-curve-getEndPoint en) 0) ptsmr))
		   T)
	       (setq i 0
		     l 0
		     ptsmr (reverse ptsmr))									;list REVERSE back.
	(repeat (1- (length ptsmr))										;mark diameters of main pipe
	  (setq pt1dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsmr))))
		pt2dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsmr))))
		l (+ l (cdr (nth i ptsmr)))
		txt (_getDia l)
		i (1+ i))
  (princ)
