Lisp to place pipe dia
tanvirme2k9
Message 1 of 35
tanvirme2k9
Hi all,
I am interested in a lisp that will insert pipe diameter. The pipe is just a line or polyline. Blocks are placed on the pipe at different distances. The pipe dia will be placed in between two blocks with a dia symbol according to the following rule –
The number of block       Dia
<=2                                 1”
2< No. of blocks <=3       1.25”
3< No. of blocks <=5       1.5”
5< No. of blocks <=10     2”
For better understand please see the attached file. Thanks in advance.
Replies (34)
Message 21 of 35
tanvirme2k9
When I select the main pipe it shows (Debugging showed the same error)
:ERROR-BREAK bad argument type : 2D/3D point :1.0
Message 22 of 35
ВeekeeCZ
I see, try this
Spoiler
(vl-load-com)
(defun C:PipesDia (/ *error* _SortPtListByDist _plDirCheck _ssFilter _getDia oVAR doc
	             ss sspl ssm ensel en p i l pts ptm ptsa ptsm ptsmr skip pt1dist pt2dist)
 (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
   (if sspts (repeat (sslength sspts)
	       (entdel (ssname sspts 0))
	       (ssdel (ssname sspts 0) sspts)))
    (foreach e oVAR (setvar (car e) (cdr e)))
    (vla-endundomark doc)
    (princ))
;Modified. Orig By BlackBox, http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
 (defun _SortPtListByDist  (ptList en lst)
  (mapcar
    (function (lambda (x / ptList2)
		(if lst
		  (setq ptList2 (car (cons (cdar x) ptList2)))
		  (setq ptList2 (append (cdar x) ptList2)))))
    (vl-sort (mapcar
	       (function (lambda (x / pt ptlist2)
			   (setq ptlist2 (cons (cons (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (if lst (car x) x) T))
						      x)
						 ptlist2))))
	       ptList)
	     (function (lambda (x y)
			 (< (caar x)
			    (caar y)))))))
  (defun _plDirCheck (ss / i en enl enr sspt)
    (setq sspt (ssadd))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i))))
      (setq enl (entlast))
      (command "_.POINT" (vlax-curve-getPointAtDist
			   en
			   (if (< 50 (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
			     20
			     0)))
      (if (/= enl (entlast))
	(ssadd (entlast) sspt)))
    (initget "Quit")
    (setq ensel (entsel "\nDirections of polylines are OK? No, select one to reverse [Quit] <OK>: "))
    (cond ((eq ensel "Quit")								;Quit, leave with nil
	   (command "_.ERASE" sspt ""))
	  ((not ensel)									;OK, leave with T
	   T)
	  ((wcmatch (cdr (assoc 0 (entget (setq enr (car ensel))))) "LWPOLYLINE,LINE") 	;Reverse, go again
	   (command "_.REVERSE" enr "")
	   (princ "\nPolyline was reversed.")
	   (setq sspt nil)
	   (_PLDirCheck ss))
	  (T 										;Wrong selection go again
	   (setq sspt nil)
	   (_PLDirCheck ss))))
  (defun _ssFilter (ss code flt / ssn)
    (setq ssn (ssadd)
	  i (sslength ss))
    (while (not (minusp (setq i (1- i))))
      (if (wcmatch (cdr (assoc code (entget (ssname ss i)))) flt)
	(ssadd (ssname ss i) ssn)))
    ssn)
  (defun _getDia (i / )
    (cond ((< i 2)   "%%c1\"")
	  ((< i 3)   "%%c1.25\"")
	  ((< i 5)   "%%c1.5\"")
	  ((< i 10)  "%%c2\"")
	  ((< i 20)  "%%c2.5\"")
	  ((< i 40)  "%%c3\"")
	  ((< i 100) "%%c4\"")
	  ((< i 275) "%%c6\"")
	  (T         "%%c")))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (foreach e '(CMDECHO OSMODE ORTHOMODE PDMODE CLAYER CECOLOR LUNITS)
    (setq oVAR (cons (cons e (getvar e)) oVAR)))
  (setvar 'CMDECHO 0)
  (setvar 'ORTHOMODE 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (setvar 'LUNITS 4)
  (if (and (princ "\nNeed Blocks and (Poly)lines, ")
	   (setq ss (ssget '((0 . "INSERT,LWPOLYLINE,LINE"))))
	   (setq sspl (ssget "_P" '((0 . "LWPOLYLINE,LINE"))))					;filter origin ss for PL/Lines only
	   (setq p (sslength sspl))
	   (> p 0)
	   (setq ss (_ssFilter ss 0 "INSERT"))							;filter origin ss for Block only
	   (> i 1)
	   (not (command "_.-LAYER" "_M" "0" ""))
	   (setvar 'CECOLOR "2")
	   (_plDirCheck sspl)
	   (setvar 'CECOLOR (cdr (assoc 'CECOLOR oVAR)))
	   (not (command "_.-LAYER" "_M" "Pipe Dia" "_C" 170 "" ""))
	     (setq ptsa (cons (cdr (assoc 10 (entget (ssname ss i)))) ptsa)))			;make a list of blocks ins points
	   (setq ssm (ssadd))
    (progn
      (while (not (minusp (setq p (1- p)))) 							;for all polylines
        (setq en (ssname sspl p)
	      pts nil)
        (if (and (foreach e ptsa								;enclose blocks to its polylines (less 10)
	  	   (if (> 10 (distance e (setq pt (vlax-curve-getClosestPointTo en e))))
		     (setq pts (cons pt pts))
		     T))
	         (if pts
		   (setq pts (_SortPtListByDist pts en nil))					;sort by dist
		   (progn
		     (ssadd en ssm)								;ss for main pipe
		     nil))
		 (setq ptsm (cons (cons (vlax-curve-getEndPoint en) (length pts)) ptsm))  	;make pairs of (pt end of pipe + numb. of blocks) for main pipe
	         (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 	  	;add last point of pipe without a block
			   (vlax-curve-getDistAtPoint en (last pts)))
		        10)
		   (setq pts (append pts (list (vlax-curve-getEndPoint en))))
		   T)
		 (setq i 0)
	  (repeat (1- (length pts))								;mark diameters of all but main pipe.
	    (setq pt1dist (vlax-curve-getDistAtPoint en (nth i pts))
		  pt2dist (vlax-curve-getDistAtPoint en (nth (1+ i) pts))
		  ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2)))	;middle point
		  txt (_getDia i)
		  i (1+ i))
	    (command "_.TEXT" ptm "1\'3\"" "" txt))))
      (if (and (cond ((= (sslength ssm) 1)							;if only pipe left, take it as MAIN PIPE
		      (setq en (ssname ssm 0)))
		     (T
		      (and (setq ensel (entsel "\nSelect the MAIN PIPE <quit>: "))		;select new if more then 1 or none
			   (setq en (car ensel))
			   (wcmatch (cdr (assoc 0 (entget en))) "LWPOLYLINE,LINE"))))
	       (> (length ptsm)  1)
	       (setq ptsm (_SortPtListByDist ptsm en 0))						;sort by dist
	       (setq i 0
		     skip 0)
	       (repeat (1- (length ptsm))										;if pipes at across each other (less 5)
		 (if (< (- (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsm))))
			   (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsm)))))
			5)
		   (setq skip (+ skip (cdr (nth i ptsm)))) 							;count block of skipped pipes
		   (setq ptsmr (cons (cons (car (nth i ptsm))							;created REVERED list!! (was already sorted)
				     ptsmr)
			 skip 0))
		 (setq i (1+ i)))
	       (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))				;add last part exceeding (more 10)
			 (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (last ptsmr)))))
		        10)
		   (setq ptsmr (cons (cons (vlax-curve-getEndPoint en) 0) ptsmr))
		   T)
	       (setq i 0
		     l 0
		     ptsmr (reverse ptsmr))									;list REVERSE back.
	(repeat (1- (length ptsmr))										;mark diameters of main pipe
	  (setq pt1dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsmr))))
		pt2dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsmr))))
		l (+ l (cdr (nth i ptsmr)))
		txt (_getDia l)
		i (1+ i))
    (princ "\nWrong selection, need at least 2 BLOCKs and 1 (POLY)LINE."))
  (princ)
Message 23 of 35
tanvirme2k9
Just Increadible!
Message 24 of 35
ВeekeeCZ
@ВeekeeCZ wrote:
Dimensioning I'll do next time. ... I tried find some "block dimensioning" on web and I'm surprised I couldn't find some...
Hi, here it my last piece... This time I made two version... the first with handling of current layer and dimstyle, the second without.
Both works same... if is blocks's X coordinate range 10 times different (larger or lesser) then Y coordinate range then is horizontal or vertical continued dimension made automatically, otherwise you can pick whether dim would be horizontal, vertical or aligned.
With a layer and dimstyle handling
Spoiler
(vl-load-com)
(defun C:BlockDim ( / *error* doc oVAR ss n pts ptsx ptsy ptd d i m dir dimstl)
    (princ))
  (foreach e '(CMDECHO ORTHOMODE CLAYER)
  (setvar 'CMDECHO 	0)
  (if (and (princ "\nNeed blocks, ")
(setq ss (ssget '((0 . "INSERT")))) (< 1 (setq n (sslength ss))) (tblsearch "DIMSTYLE" (setq dimstl "ANIS")) ; <-- set DIMSTYLE (while (not (minusp (setq n (1- n)))) (setq pts (cons (cdr (assoc 10 (entget (ssname ss n)))) pts))) (setq ptsx (vl-sort pts '(lambda (p q) (< (car p) (car q))))) (setq ptsy (vl-sort pts '(lambda (p q) (< (cadr p) (cadr q))))) (setq d (abs (/ (- (car (last ptsx)) (caar ptsx)) ;xmax-xmin (- (cadr (last ptsy)) (cadar ptsy))))) ;ymax-ymin (setq i 0 m 4) ; <-- set multiplier for dim distance = m * (getvar 'DIMTXT) * (getvar 'DIMSCALE) (not (command "_.-DIMSTYLE" "_R" dimstl "_.-LAYER" "_M" "Aim-Dimension" "_C" "160" "Aim-Dimension" "")) ; <-- set LAYER ) (progn (if (and (< d 10) (> d 0.1)) (progn (initget "Horizontal Vertical Aligned") (setq dir (getkword "\nMake dimension [Horizontal/Vertical/Aligned] <Aligned>: ")))) (cond ((or (= dir "Horizontal") (> d 10)) (setq ptd (polar (nth 0 ptsx) (* 1.5 pi) (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsx)) (command "_.DIMLINEAR" "_none" (nth i ptsx) "_none" (nth (1+ i) ptsx) "_H" "_none" ptd) (setq i (1+ i)))) ((or (= dir "Vertical") (< d 0.1)) (setq ptd (polar (nth 0 ptsy) 0 (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsy)) (command "_.DIMLINEAR" "_none" (nth i ptsy) "_none" (nth (1+ i) ptsy) "_V" "_none" ptd) (setq i (1+ i)))) (T ;Aligned (setq ptd (polar (nth 0 ptsx) (+ (angle (car ptsx) (last ptsx)) (* 1.5 pi)) (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsx)) (command "_.DIMALIGNED" "_none" (nth i ptsx) "_none" (nth (1+ i) ptsx) "_none" ptd) (setq i (1+ i)))) ) ) (princ (strcat "\nError: Wrong selection of at least 2 BLOCKS or your " dimstl " DIMSTYLE is not loaded.")) ) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ) )
Without a layer and dimstyle handling (makes it into the currents)
Spoiler
(vl-load-com)
(defun C:BlockDim ( / *error* doc oVAR ss n pts ptsx ptsy ptd d i m dir)
    (princ))
  (setvar 'CMDECHO 	0)
(setq ss (ssget '((0 . "INSERT")))) (< 1 (setq n (sslength ss))) (while (not (minusp (setq n (1- n)))) (setq pts (cons (cdr (assoc 10 (entget (ssname ss n)))) pts))) (setq ptsx (vl-sort pts '(lambda (p q) (< (car p) (car q))))) (setq ptsy (vl-sort pts '(lambda (p q) (< (cadr p) (cadr q))))) (setq d (abs (/ (- (car (last ptsx)) (caar ptsx)) ;xmax-xmin (- (cadr (last ptsy)) (cadar ptsy))))) ;ymax-ymin (setq i 0 m 4)) ; <-- set multiplier for dim distance = m * (getvar 'DIMTXT) * (getvar 'DIMSCALE) (progn (if (and (< d 10) (> d 0.1)) (progn (initget "Horizontal Vertical Aligned") (setq dir (getkword "\nMake dimension [Horizontal/Vertical/Aligned] <Aligned>: ")))) (cond ((or (= dir "Horizontal") (> d 10)) (setq ptd (polar (nth 0 ptsx) (* 1.5 pi) (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsx)) (command "_.DIMLINEAR" "_none" (nth i ptsx) "_none" (nth (1+ i) ptsx) "_H" "_none" ptd) (setq i (1+ i)))) ((or (= dir "Vertical") (< d 0.1)) (setq ptd (polar (nth 0 ptsy) 0 (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsy)) (command "_.DIMLINEAR" "_none" (nth i ptsy) "_none" (nth (1+ i) ptsy) "_V" "_none" ptd) (setq i (1+ i)))) (T ;Aligned (setq ptd (polar (nth 0 ptsx) (+ (angle (car ptsx) (last ptsx)) (* 1.5 pi)) (* m (getvar 'DIMTXT) (getvar 'DIMSCALE)))) (repeat (1- (length ptsx)) (command "_.DIMALIGNED" "_none" (nth i ptsx) "_none" (nth (1+ i) ptsx) "_none" ptd) (setq i (1+ i)))) ) ) ) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ) )
Message 25 of 35
tanvirme2k9
I don't know the way to appriciate the effort. Thanks...
PipeDia - The crosses are seen even in the blocks of locked layer. Not a big problem but makes some confusion.
Message 26 of 35
ВeekeeCZ
Not really sure what you mean... But try to add "_:L" into this line:
(setq ss (ssget "_:L" '((0 . "INSERT,LWPOLYLINE,LINE"))))
If is not that, post a screenshot.
Message 27 of 35
tanvirme2k9
See the attached image.
Message 28 of 35
ВeekeeCZ
Hmm, I see. Can you post this whole system as dwg? I'll try to figure out how to exclude them.
Message 29 of 35
tanvirme2k9
I have attached the file. (See also another issue in it.)
Message 30 of 35
ВeekeeCZ
You have not.....
Message 31 of 35
tanvirme2k9
Oops! sorry.
Message 32 of 35
ВeekeeCZ
Ok, I fixed mine...
Spoiler
(vl-load-com)
    (princ))
  (mapcar
		(if lst
    (vl-sort (mapcar
						      x)
						 ptlist2))))
	       ptList)
			 (< (caar x)
			    (caar y)))))))
    (setq sspt (ssadd))
			   en
			     20
			     0)))
    (initget "Quit")
	   T)
	   (setq sspt nil)
	   (_PLDirCheck ss))
	   (setq sspt nil)
	   (_PLDirCheck ss))))
    (setq ssn (ssadd)
	  i (sslength ss))
    ssn)
    (cond ((<= i 2)   "%%c1\"")
	  ((<= i 3)   "%%c1.25\"")
	  ((<= i 5)   "%%c1.5\"")
	  ((<= i 10)  "%%c2\"")
	  ((<= i 20)  "%%c2.5\"")
	  ((<= i 40)  "%%c3\"")
	  ((<= i 100) "%%c4\"")
	  ((<= i 275) "%%c6\"")
	  (T          "%%c")))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (setvar 'LUNITS 4)
	   (> p 0)
	   (> i 1)
	   (_plDirCheck sspl)
	   (setq ssm (ssadd))
    (progn
	      pts nil)
		     T))
	         (if pts
		   (progn
		     nil))
		        10)
		   T)
		 (setq i 0)
		  txt (_getDia (1+ i))
		  i (1+ i))
		     (T
	       (> (length ptsm)  1)
	       (setq i 0
		     skip 0)
			5)
				     ptsmr)
			 skip 0))
		 (setq i (1+ i)))
		        10)
		   T)
	       (setq i 0
		     l 0
		txt (_getDia l)
		i (1+ i))
    (princ "\nTerminated by user or by error: Wrong selection, need at least 2 BLOCKs and 1 (POLY)LINE."))
  (princ)
Now you need fix your drawing - fix your blocks... in the block editor explode the inner block, all objects put into layer 0. Just keep colors. Then before you're apply this routine isolate layers of blocks, pipes and main pipe (text layer is not necessary) first.
Message 33 of 35
ВeekeeCZ
I fixed the minor problem causing error...
Spoiler
(vl-load-com)
(defun C:BlockDim ( / *error* doc oVAR ss n pts ptsx ptsy ptd d d0 i m dir)
    (princ))
  (setvar 'CMDECHO 	0)
			   (if (zerop (setq d0 (- (cadr (last ptsy)) (cadar ptsy)))) ;ymax-ymin
			     0.001
			     d0))))
	   (setq i 0
		 m 0)) ; <--  set multiplier for dim distance = m * (getvar 'DIMTXT) * (getvar 'DIMSCALE)
    (progn
      (if (and (< d 10)
	       (> d 0.1))
	(progn
		 (> d 10))
			      (* 1.5 pi)
			"_H"
			"_none" ptd)
	       (setq i (1+ i))))
		 (< d 0.1))
			      0
			"_V"
			"_none" ptd)
	       (setq i (1+ i))))
	    (T ;Aligned
				 (* 1.5 pi))
			"_none" ptd)
	       (setq i (1+ i))))
  (princ)
Message 34 of 35
tanvirme2k9
"I fixed the minor problem causing error..." - but it's placing the dimension on the pipe.
Message 35 of 35
ВeekeeCZ
Jeee... sorry. I was trying something... See this line and change multiplier from 0 to 4.
	   (setq i 0
