Sprinkler network Pipe Sizing
107199
107199
hi all,
when using this lisp with this file there is sum problems:
1-it can't recognize the main pipe.
2-text height for pipe size is 15 but i work with 200.
3-text layer is the same for the pipe.
4-text is without leader with is just a line on another layer
note that:
*Text Layer "FIRE-TEXT-P"
*Branch layer "FIRE-PIPE-P"
*Main Layer "FIRE-Main-P"
(vl-load-com)
(defun C:PipesDia (/ *error* _SortPtListByDist _plDirCheck _ssFilter _getDia oVAR doc
	             ss sspl ssm ensel en p i l pts ptm ptsa ptsm ptsmr skip pt1dist pt2dist)
 (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
   (if sspts (repeat (sslength sspts)
	       (entdel (ssname sspts 0))
	       (ssdel (ssname sspts 0) sspts)))
    (foreach e oVAR (setvar (car e) (cdr e)))
    (vla-endundomark doc)
    (princ))
;Modified. Orig By BlackBox, http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
 (defun _SortPtListByDist  (ptList en lst)
  (mapcar
    (function (lambda (x / ptList2)
		(if lst
		  (setq ptList2 (car (cons (cdar x) ptList2)))
		  (setq ptList2 (append (cdar x) ptList2)))))
    (vl-sort (mapcar
	       (function (lambda (x / pt ptlist2)
			   (setq ptlist2 (cons (cons (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (if lst (car x) x) T))
						      x)
						 ptlist2))))
	       ptList)
	     (function (lambda (x y)
			 (< (caar x)
			    (caar y)))))))
  (defun _plDirCheck (ss / i en enl enr sspt)
    (setq sspt (ssadd))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i))))
      (setq enl (entlast))
      (command "_.POINT" (vlax-curve-getPointAtDist
			   en
			   (if (< 50 (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
			     20
			     0)))
      (if (/= enl (entlast))
	(ssadd (entlast) sspt)))
    (initget "Quit")
    (setq ensel (entsel "\nDirections of polylines are OK? No, select one to reverse [Quit] <OK>: "))
    (cond ((eq ensel "Quit")								;Quit, leave with nil
	   (command "_.ERASE" sspt ""))
	  ((not ensel)									;OK, leave with T
	   T)
	  ((wcmatch (cdr (assoc 0 (entget (setq enr (car ensel))))) "LWPOLYLINE,LINE") 	;Reverse, go again
	   (command "_.REVERSE" enr "")
	   (princ "\nPolyline was reversed.")
	   (setq sspt nil)
	   (_PLDirCheck ss))
	  (T 										;Wrong selection go again
	   (setq sspt nil)
	   (_PLDirCheck ss))))
  (defun _ssFilter (ss code flt / ssn)
    (setq ssn (ssadd)
	  i (sslength ss))
    (while (not (minusp (setq i (1- i))))
      (if (wcmatch (cdr (assoc code (entget (ssname ss i)))) flt)
	(ssadd (ssname ss i) ssn)))
    ssn)
  (defun _getDia (i / )
    (cond ((<= i 2)   "25 mm")
	  ((<= i 3)   "32 mm")
	  ((<= i 5)   "40 mm")
	  ((<= i 10)  "50 mm")
	  ((<= i 20)  "65 mm")
	  ((<= i 40)  "80 mm")
	  ((<= i 100) "100 mm")
	  ((<= i 275) "150 mm")
	  (T          "%%c")))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (foreach e '(CMDECHO OSMODE ORTHOMODE PDMODE CLAYER CECOLOR LUNITS)
    (setq oVAR (cons (cons e (getvar e)) oVAR)))
  (setvar 'CMDECHO 0)
  (setvar 'ORTHOMODE 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (setvar 'LUNITS 4)
  (if (and (princ "\nNeed Blocks and (Poly)lines, ")
	   (setq ss (ssget "_:L" '((0 . "INSERT,LWPOLYLINE,LINE"))))
	   (setq sspl (ssget "_P" '((0 . "LWPOLYLINE,LINE"))))					;filter origin ss for PL/Lines only
	   (setq p (sslength sspl))
	   (> p 0)
	   (setq ss (_ssFilter ss 0 "INSERT"))							;filter origin ss for Block only
	   (> i 1)
	   (not (command "_.-LAYER" "_M" "Pipe Dia" "_C" 170 "" ""))
	   (setvar 'CECOLOR "2")
	   (_plDirCheck sspl)
	   (setvar 'CECOLOR (cdr (assoc 'CECOLOR oVAR)))
	     (setq ptsa (cons (cdr (assoc 10 (entget (ssname ss i)))) ptsa)))			;make a list of blocks ins points
	   (setq ssm (ssadd))
    (progn
      (while (not (minusp (setq p (1- p)))) 							;for all polylines
        (setq en (ssname sspl p)
	      pts nil)
        (if (and (foreach e ptsa								;enclose blocks to its polylines (less 10)
	  	   (if (> 10 (distance e (setq pt (vlax-curve-getClosestPointTo en e))))
		     (setq pts (cons pt pts))
		     T))
	         (if pts
		   (setq pts (_SortPtListByDist pts en nil))					;sort by dist
		   (progn
		     (ssadd en ssm)								;ss for main pipe
		     nil))
		 (setq ptsm (cons (cons (vlax-curve-getEndPoint en) (length pts)) ptsm))  	;make pairs of (pt end of pipe + numb. of blocks) for main pipe
	         (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 	  	;add last point of pipe without a block
			   (vlax-curve-getDistAtPoint en (last pts)))
		        10)
		   (setq pts (append pts (list (vlax-curve-getEndPoint en))))
		   T)
		 (setq i 0)
	  (repeat (1- (length pts))								;mark diameters of all but main pipe.
	    (setq pt1dist (vlax-curve-getDistAtPoint en (nth i pts))
		  pt2dist (vlax-curve-getDistAtPoint en (nth (1+ i) pts))
		  ptm (vlax-curve-getPointAtDist en (+ pt1dist (/ (- pt2dist pt1dist) 2)))	;middle point
		  txt (_getDia (1+ i))
		  i (1+ i))
	    (command "_.TEXT" ptm "1\'3\"" "" txt))))
      (if (and (cond ((= (sslength ssm) 1)							;if only pipe left, take it as MAIN PIPE
		      (setq en (ssname ssm 0)))
		     (T
		      (and (setq ensel (entsel "\nSelect the MAIN PIPE <quit>: "))		;select new if more then 1 or none
			   (setq en (car ensel))
			   (wcmatch (cdr (assoc 0 (entget en))) "LWPOLYLINE,LINE"))))
	       (> (length ptsm)  1)
	       (setq ptsm (_SortPtListByDist ptsm en 0))						;sort by dist
	       (setq i 0
		     skip 0)
	       (repeat (1- (length ptsm))										;if pipes at across each other (less 5)
		 (if (< (- (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsm))))
			   (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsm)))))
			5)
		   (setq skip (+ skip (cdr (nth i ptsm)))) 							;count block of skipped pipes
		   (setq ptsmr (cons (cons (car (nth i ptsm))							;created REVERED list!! (was already sorted)
				     ptsmr)
			 skip 0))
		 (setq i (1+ i)))
	       (if (> (- (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en))				;add last part exceeding (more 10)
			 (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (last ptsmr)))))
		        10)
		   (setq ptsmr (cons (cons (vlax-curve-getEndPoint en) 0) ptsmr))
		   T)
	       (setq i 0
		     l 0
		     ptsmr (reverse ptsmr))									;list REVERSE back.
	(repeat (1- (length ptsmr))										;mark diameters of main pipe
	  (setq pt1dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth i ptsmr))))
		pt2dist (vlax-curve-getDistAtPoint en (vlax-curve-getClosestPointTo en (car (nth (1+ i) ptsmr))))
		l (+ l (cdr (nth i ptsmr)))
		txt (_getDia l)
		i (1+ i))
    (princ "\nTerminated by user or by error: Wrong selection, need at least 2 BLOCKs and 1 (POLY)LINE."))
  (princ)
rkmcswain
Maybe @ВeekeeCZ can help - looks like that code is from this thread.
ВeekeeCZ
Hmm, I've tried the routine on your drawing - not that bad.
- fixing text height is very simple, find and replace "1\'3\"" with 200 (no need for quote marks)
- changing texts to mleaders we can do later.
BUT FIRST, go back to the other thread where you found it, you can use @rkmcswain's link (thanks for finding!), go
fo there and READ at least the post #15 and FIX YOUR DRAWING AS DESCRIBED THERE. Then we can move on...
Edit: Also get rid of Z coords, make it flat!
Dear sir,
 I’ve modified the text height and I reviewed the old thread and now I understand the steps to use this lisp. The remaining issues are :
  • The mleader and Text style as per the attached drawing.
  • When trying to reverse the direction on a line It on allows to modify one line is there a way to be multi select.
  • The clouded branches in the attached file hasn’t been sized.
  • When loading the lisp it shows the last direction point and doesn’t disappear after selection even the selection doesn’t include these points.
(vl-load-com)
    (princ))
  (mapcar
		(if lst
    (vl-sort (mapcar
						      x)
						 ptlist2))))
	       ptList)
			 (< (caar x)
			    (caar y)))))))
    (setq sspt (ssadd))
			   en
			     20
			     0)))
    (initget "Quit")
	   T)
	   (setq sspt nil)
	   (_PLDirCheck ss))
	   (setq sspt nil)
	   (_PLDirCheck ss))))
    (setq ssn (ssadd)
	  i (sslength ss))
    ssn)
	  ((<= i 3)   "32 mm")
	  ((<= i 5)   "40 mm")
	  ((<= i 10)  "50 mm")
	  ((<= i 20)  "65 mm")
	  ((<= i 40)  "80 mm")
	  (T          "%%c")))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
  (setvar 'PDMODE 3)
  (setvar 'LUNITS 4)
	   (> p 0)
	   (> i 1)
	   (not (command "_.-LAYER" "_M" "FIRE-TEXT-P" "_C" 2 "" ""))
	   (_plDirCheck sspl)
	   (setq ssm (ssadd))
    (progn
	      pts nil)
		     T))
	         (if pts
		   (progn
		     nil))
		        10)
		   T)
		 (setq i 0)
		  i (1+ i))
	    (command "_.TEXT" ptm 200 "" txt))))
		     (T
	       (> (length ptsm)  1)
	       (setq i 0
		     skip 0)
			5)
				     ptsmr)
			 skip 0))
		 (setq i (1+ i)))
		        10)
		   T)
	       (setq i 0
		     l 0
		txt (_getDia l)
		i (1+ i))
  (princ)
ВeekeeCZ
Hi, sorry for delay.
Unfortunately I have bad news. I've played with this program for a while - made all the changes that you've asked.
BUT !!! the issue is the part in the yellow rectange. You have sprinkles placed on the "main" pipe - the alogithem does not count with this possibility and it would mean rewrite it all over from a scratch -- and I don't really want to do that. Sorry.
- for multiple reverse you need to pick a single entity as the first one, then you can make window selection.
- in the manual part, where you're asked for selection main pipes "Select pipe: " - you need to do that in the order from tiniest to biggest.
ВeekeeCZ
Ok, better news - found some not that drastic solution. I'm aware that this is less comfortable - but I hope - still better then nothing.
- those problematic sprinclers you cannot select in first selection... see the SCREENCAST
