Set up carefully enough, Ordinate Dimensions with Alternate Units will do exactly that.
Kent Cooper
spinalfarm wrote...
Board,
Re: AutoCAD 2009
Is it possible to create a (somewhat) intelligent floor plan spot elevation tag with two units of
measurement? Manually enter in the height of the floor level in imperial feet (ft.) & inches (in.)
& have an automatic conversion to metric meters (m.) in brackets beside or below it?
This would ideally be a block with I am assuming a field with a formula?
Any help or suggestions would be super,
-STU
