"I prefer to use the control vertices method of spline. I know I can set it to cv by doing the command spline > m > cv or going to system variable monitor and changing SPLMETHOD to 1 for cv. The issue I have is when I close and open AutoCAD SPLMETHOD reverts to 0 for fit. Is there a way to make SPLMETHOD stop defaulting to 0 when AutoCAD opens?"
That was my original post from earlier today and it was suggested to try my luck over here by a technical support specialist to ask for help with a lisp routine to set the SPMETHOD to 1 for CV on startup.
