SPLMETHOD default to CV
jhaylesWGNPZ
jhaylesWGNPZ
"I prefer to use the control vertices method of spline.  I know I can set it to cv by doing the command spline > m > cv or going to system variable monitor and changing SPLMETHOD to 1 for cv. The issue I have is when I close and open AutoCAD SPLMETHOD reverts to 0 for fit. Is there a way to make SPLMETHOD stop defaulting to 0 when AutoCAD opens?"
That was my original post from earlier today and it was suggested to try my luck over here by a technical support specialist to ask for help with a lisp routine to set the SPMETHOD to 1 for CV on startup.
ronjonp
You need to put (setvar 'splmethod 1) in your startup. Looks like 0 is the default for CAD.
jhaylesWGNPZ
How/where do I do that?
ronjonp
Create a file called SPLMETHOD.LSP and put (setvar 'splmethod 1) inside of it and save somewhere ( preferably in an AutoCAD search path ).
Then APPLOAD and go to 'startup suite.
Browse to your file and it should load up on each drawing open.
jhaylesWGNPZ
That did it. Thanks alot.
ronjonp
Glad to help! 🙂
