pnpISO.exe vs PCF vs isoconfig.xml - Problem to take into account coordinate offsets locations and rotation on AutoCAD Plant 3D
david.lascour
Message 1 of 1
david.lascour
Hi everyone.
I'm working on a project with several isometric configurations.
Several configurations have been created to include coordinate changes (X, Y, Z and rotate Z).
I created an excel program that allows me to generate the PNPISO bacth file to generate the DWG isometrics according to their associated configurations
The program works well but the problem is that coordinate changes are ignored at this stage. The generated isometrics are therefore not good.
The <advancedDefault....> line in the isoconfig.xml file is ignored...
I understand that the change of coordinates is made in the previous step when generating the PCF.
The _plantpcfexport command does not generate PCFs under an Isometric configuration (including changes of coordinates).
My questions :
1- Do you have a solution to this problem?
2- Do you know a tool to convert the coordinates of a PCF file like the first action when you perform an _plantproductioniso command with dialog box?
A big thank-you !
David
Replies (0)
