LISP or other to use PLANT 3D Command "-plantproductioniso" to generate massive Isometrics
david.lascour
Message 1 of 1
david.lascour
Hi everyone.
I'm working on a project with several isometric configurations.
Several configurations have been created to include coordinate changes (X, Y, Z and rotate Z).
Can the -plantproductioniso command be used in a LISP file? After several tries I can't find the execution sequence...
But the problem is how to inform it with all the following arguments?
The dialog box allows you to choose one or more lines, choose an ISO configuration, put the REVISION...
for example :
I have several lines, each line has its own ISO configuration and its own revision. What are the LISP command lines to fill in?
LINE_01 with ISOCONFIG01 with REV 2
LINE_02 with ISOCONFIG02 with REV 0
LINE_03 with ISOCONFIG03 with REV 3
A big thank-you !
David
Replies (0)
