something wrong in this code ?  if yes please help.
DOODLEANU
Message 1 of 11
DOODLEANU
(defun c:GLASS ()
  ;; Unfreeze all layers
  (command "._-layer" "thaw" "GLASSWALL" "")
  (command "._-layer" "thaw" "BLOCKWALL" "")
  (command "._-layer" "thaw" "GYPSUMWALL" "")
  ;; Set "GLASS" as current layer
  (command "._-layer" "make" "GLASSWALL" "")
  ;; Freeze other two layers
  (command "._-layer" "freeze" "BLOCKWALL" "")
  (command "._-layer" "freeze" "GYPSUMWALL" "")
 ;; Select all Polylines feom the GLASSWALL layer *****NOT WORKING***
  (setq ss (ssget "X" (list (cons 8 "GLASSWALL") (cons 0 "POLYLINE"))))
  (princ "\nGLASS is current, others frozenand all polylines are selected.")
  (princ)
Replies (10)
Message 2 of 11
cadffm
nothing wrong, works technically perfect.
You forgot to say what you expect! I guess you want to create a grip&pickset, so polylines are selected?
SSGET created a selectionset ONLY,
you can access this selectionset by object selection method PREVIOUS (P)
Solution for your Lisp: Add a SSSETFIRST statement!
https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-4076CD9D-1C66-4C73-ACC0-3A6CD0B0D2D8
(defun c:GLASS ()
(command "_.-LAYER" "_n" "GLASSWALL,BLOCKWALL,GYPSUMWALL" "")
  (if (setq ss (ssget "X" (list (cons 8 "GLASSWALL") (cons 0 "POLYLINE")))) ;Alternative for all Plines: (cons 0 "*POLYLINE"))))
      (progn
	(sssetfirst nil ss)
	(command "_.regen")
      (princ "\nNothing selected")
  (princ)
Sebastian
Message 3 of 11
DOODLEANU
I was expecting all polylines from the "GLASSWALL" layer to be selected after all the layer modifications.  will that be possible?
Message 4 of 11
ВeekeeCZ
Just in case you don't know...
'(0 . "LWPOLYLINE")
"regular" polyline is "LWPOLYLINE"
3D polyline is "POLYLINE"
So... as suggested by @cadffm  *POLYLINE would cover both types.
Message 5 of 11
ВeekeeCZ
And if I may suggest...
Better wrap those into single command...
(command "layer" "thaw" "glasswall,blockwall,gypsumwall" "") ... that way it would be 1 step for UNDO or LAYERP...
Also can add
(command "layer" "thaw" "glasswall,blockwall,gypsumwall" "make" "glasswall" "")
Message 6 of 11
Moshe-A
@DOODLEANU ,
the regen command cancels the effect of (sssetfirst), remove it
Message 7 of 11
DOODLEANU
Got it, thank you so much for the support.
Message 8 of 11
cadffm
which version you are taliing about?
That shouldn't be.
( I NEED this regen in my test version/PC/Graphicscard) , or I have to click in editor window, to show highlight&grips)
Sebastian
Message 9 of 11
ВeekeeCZ
Just for the record... a quick research.
it's (command "layer" "freeze" ...) that cause the trouble. Not thaw or make, just freeze. I've tried various methods less disturbing to redraw/active screen but nothing else works but regen.
So if layer must be frozen this way, it requires regen to show grips by (sssetfirst). But it could be done before (sssetfirst) so it's a bit more efficient since grips don't have to be redrawn.
Ultimate solution is to use other freezing methods - entmode, activex method or setpropertyvalue... all works without need to regen.
Message 10 of 11
cadffm
He BeekeeCZ,
"So if layer must be frozen this way, it requires regen. "
1. No!?, Command Layer-freeze works without a manually/additional regen command, like ON/OFF too.
    (command "_.-layer" "_freeze" "Test" "") works directly
2. I read Moshe-A comment different. He said highlight&grips disappering, because of my following REGEN command.
     That would be new for me, so I ask about the program version.
On the contrary, I absolutely need a refresh so that sssetfirst is immediately visible on the screen.
Your opinion?
Sebastian
Message 11 of 11
ВeekeeCZ
I should have add that it's in context of sssetfirst usage. So I'm with you.
