Rebar array , Modification request ، please
abdulellah.alattab
abdulellah.alattab
Greetings to all, is it possible to modify this LISP by freeing it from any dependence on system variable or annotation scale or cuix interface, so that it works in the following way. 1- The user starts by entering a number that is considered a scale for enlarging or reducing, then multiplying or dividing it by the value of the diameter of the rod and the distance between the rods. 2- The user enters the value of the diameter of the rod, 3- The user enters the distance between the rods 5- The program starts distributing them as in the original LISP.
Attached :
A picture has been attached to show how the original program works.
abdulellah.alattab
Lisp code file
abdulellah.alattab
Orginal lisp The original Lisp has the ability to press the tab key to switch the direction in which the bars are drawn.
paullimapa
this is copyrighted code...have you tried going back to speak to the author:
Copyrighted by Linh Pham Vu Hong
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
abdulellah.alattab
some thing do seam function
