slab section profile polyline
DC-MWA
DC-MWA
Hi all,
In need of a way to quickly draw a slab profile by user input. Maybe something similar I can use as a starting point?
See image of what I'm trying to achieve...
Thank you.
Sea-Haven
Happy to do something for you, but it would be from a commercial point of view, this is like question 1, I know question 2 3 4 5 will follow. I have 30 years experience and know the request will grow.
I am suggesting its more efficient to code multiple shapes as you have a consistent approach.
The attached Pdf gives you an idea of some of the stuff I have done.
The input would be via a dialouge screen so its more descriptive rather than just line after line input. Beam cross sections are pretty straight forward.
An example is a waffle slab just pick outside edge and waffles are placed including arcs in slab shape.
DC-MWA
Well thank you for the reply.
Although... I primarily do custom homes in the evening. I use perimeter footings as shown, "T" footing with raised wood floor framing, stemwall and retaining walls now and then and that's about it. During the day, the commercial applications  I do vary so much from huge Mat slabs to caissons, and on and on... To many variations and applications to try and solve with one lisp program.
I am pretty much trying to streamline my residential applications so my drafter can get it right and do it fast.
Moshe-A
@DC-MWA  hi,
here is my version. of course it better done with  dialog box and this is on you Smiley LOL
enjoy
moshe
(defun C:SlabSec (/ set_defaults askReal ;local functions
		    sysvars^ slab-length slab-thickness left-beam-depth right-beam-depth p0 p1 p2 p3 p4 p5 p6)
 (defun set_defaults ()
  (mapcar
    '(lambda (var def)
      (if (= (getvar var) 0)
       (setvar var def)
     ); lambda
    sysvars^
   '(1200.0 100.0 280.0 320.0)
  ); mapcar
 ); set_defaults
 (defun askReal (msg def / ask)
  (initget (+ 2 4))
  (if (not (setq ask (getreal (strcat "\n" msg " <" (rtos def 2) ">: "))))
   (setq ask def)
   (setq def ask)
 ); askReal
 ; here start command
 (setq sysvars^ '("userr1" "userr2" "userr3" "userr4"))
 (set_defaults)
 (if (and
       (setvar (nth 0 sysvars^) (setq slab-length 	(askReal "Slab length"      (getvar (nth 0 sysvars^)))))
       (setvar (nth 1 sysvars^) (setq slab-thickness  	(askReal "Slab thickness"   (getvar (nth 1 sysvars^)))))
       (setvar (nth 2 sysvars^) (setq left-beam-depth 	(askReal "Left beam depth"  (getvar (nth 2 sysvars^)))))
       (setvar (nth 3 sysvars^) (setq right-beam-depth 	(askReal "Right beam depth" (getvar (nth 3 sysvars^)))))
       (setq p0 (getpoint "Specify upper left corner: "))
  (command "._pline" p0 "_w" "0" "0"
           (setq p1 (list (+ (car p0) slab-length) (cadr p0)))
	   (setq p2 (list (car p1) (- (cadr p1) right-beam-depth)))
	   (setq p3 (list (- (car p2) right-beam-depth) (cadr p2)))
	   (setq p4 (list (car p3) (+ (cadr p3) (- right-beam-depth slab-thickness))))
	   (setq p5 (list (- (car p4) (- slab-length left-beam-depth right-beam-depth)) (cadr p4)))
	   (setq p6 (list (car p5) (- (cadr p5) (- left-beam-depth slab-thickness))))
	   (list (- (car p6) left-beam-depth) (cadr p6))
	   "_close")
 ); if
 (princ)
Sea-Haven
You are right its a case of not one lisp but rather  a series of functions that draw the required output. My house package has around 104 lisp's it it gets options added as required.
Most footings have a common theme single strip L T etc so the approach is ask questions and draw the answer. In your image you need also the reinforcement to be added.
I appreciate your designs vary but again can be broken down into similar objects. The other way is to use dynamic blocks.
Moshe-a I have attached my multival dcl it creates a dcl on the fly with as many lines as you want, its called via 2 lines of code. I like the variable names makes it easier to see whats going on, like you I use default values. Here is this project add or remove required input 8 7 is input characters, ans is a list of strings of the returned values. Use nth etc.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Double beam edge" "Enter length" 8 7 "1000" "Enter slab thickness" 8 7 "100" "Beam depth" 8 7 "330" "Beam width" 8 7 "300")))
The other thing I would have added was the dimensions already mentioned the reo missing.
Could be expanded to edgebeam1 edgebeam 2 being different pretty quick.
Lastly to dc-mwa if your happy to post some images or pdfs happy to look at whats involved in automating them. Private message etc.
DC-MWA
Thank you Moshe.  I was able to take this and modify it slightly to do what I needed.
DC-MWA
Thank you for you input. On this one I think I'll just keep it simple.
