simple request to get block scale by block name
I am trying to get the scale from a block that i know the name of and assign it to variable.
when i resize my title block i need to find the x scale of a block named logo and set "dscale" to that value so i can insert blocks where i need them by that scale.
what i have doesnt seem to work.
(setq en("business logo"))
(setq enlist(entget en))
(setq dscale (cdr(assoc 41 enlist)))
when i run it and ask the user to select the block (like below) it works
(setq en(car (entsel "\n Select an image:")))
but i need it to grab the block by the name "business logo" and grab the x scale from it
ive tried the
(if (tblsearch "BLOCK" "business logo")
but i seem to not be able to figure out why this keeps giving me errors
seems like a simple thing to do but i am stuck and need to brush up on my lisp
any help would be appreciated
Kent1Cooper
I assume the
is to set the Block name into the 'en' variable, but if so, the name as a text string must not be in parentheses.  Do it:
(setq en "business logo")
Then, this:
is invalid, because (entget) requires an entity name, such as that of a Block reference or insertion, not just a Block's name, which is unattached to any drawn entity [and therefore can't have, for example, scale factors].  To have the routine find a Block by that name and get its entity data, you will need it to search the drawing for insertions of Blocks by that name [even if there's only one], and get the entity data from the first [even if it's the only] Block insertion that it finds.  Try this:
(setq enlist (entget (ssname (ssget "_X" (list (cons 2 en))) 0)))
You could accomplish the same without the need for the 'en' variable at all, if you prefer:
(setq enlist (entget (ssname (ssget "_X" '((2 . "business logo"))))))
Note the difference between
... "_X" (list (cons 2 en))...
which needs to build its filter list with the explicit (list) function because it needs to evaluate the 'en' variable, and
... "_X" '((2 . "business logo"))...
which can use the "shortcut" version of the (quote) function [the apostrophe] to make the list, since all the information is specific and nothing needs to be evaluated but can be read directly [i.e. "quoted"].
Some would include the entity type in the (ssget) filter list:
(setq enlist (entget (ssname (ssget "_X" '((0 . "INSERT") (2 . "business logo"))))))
But unless you have any other kinds of entities with (assoc 2) entries that could be "business logo" [which seems highly unlikely], that shouldn't be necessary.
Then the:
(setq dscale (cdr (assoc 41 enlist)))
should work as expected.
Kent Cooper, AIA
theseb1994
Hi there,
I'm trying to do something pretty similar. Here is the code I'm using but I keep getting a "too few arguments" error.
(setq enlist(entget(ssname(ssget "_X" '((0 . "BLOCK")(2 . "_block_name"))))))
(setq dscale(cdr(assoc 41 enlist)))
Any help would be greatly appreciated!!
dbroad
ssname takes two arguments (ssname <selectionset> <index>)
BTW: You should avoid assumptions such as the fact that ssget will return anything by restructuring to add an if
;Will work
(setq
enlist (entget
(ssname
(ssget "_X" '((0 . "INSERT") (2 . "_block_name")))
0)
(setq dscale (cdr (assoc 41 enlist))) ;Better (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "_block_name")))) (progn (setq enlist (entget (ssname ss 0))) (setq dscale (cdr(assoc 41 enlist))))) ;Block is not a type of object. Use insert.
Architect, Registered NC, VA, SC, & GA.
theseb1994
Fantastic! Thank you so much!
