close with ESC key.
close with ESC key.
nychoe1
close with ESC key.
nychoe1
hello...
this is layer dialogue box.
when I close this box,
I want to close this box press with ESC key, do not click the x button...
let me know... please...
nychoe,
I'm not sure that it is the smartest thing to do that with esc key.
Why not use LAYERCLOSE command.
or you can make custom command
(defun c:aaa (); change aaa to your custom command
(command "_.layerclose")
Hope this help,
dicra
PvdW
nychoe,
Another option is set the system variable LAYERDLGMODE to 0. The LAYER command can use either the CLASSICLAYER or the LAYERPALETTE command, which is controlled by setting LAYERDLGMODE to 0 or 1. The CLASSICLAYER dialogue box is closed when using the ESC key.
Peter
Peter,
I agree with you, It is the best solution for problem.
dicra
nychoe1
oh~ thank you for answer...
