How do i get my lisp to load quietly?
i added a lisp file to our in house automatic loading file that checks for a certain block, & if it finds it redefines the block then runs attsync. Its much like acaddoc.lsp. Everything works great except i see on the command line that it had run. How can i make this run without it reporting to the command line. I tried to put (princ) at the end but it did not do the trick.
Shneuph
I think you probably have to set cmdecho to 0 at the beginning:
Very beginning:
(setq mycmdecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
...rest of code.,..
at end:
(setvar "cmdecho" mycmdecho)
(princ)
Hope that does it.
EDIT:
If you use variables you will probably want to set them to nil at the end as well.
(setq mycmdecho nil)
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Ok, thanks alot. I will try that
Very beginning:
...rest of code.,..
at end:
(princ)
Hope that does it.
EDIT:
Its still showing up. This is what i get:
AutoCAD menu utilities loaded.
ATTSYNC complete5 nil
Here is my code:
;;This program is to fix Wendy's Title Info Block
;;It will replace The Attribute ArialBlack With CDG Arial Black
(If (AND (tblsearch "block" "Sheet Info 24x36" (OR (= (strcase (GETVAR "PROJECTNAME")) "WENDYS")(= ln16 "IA (SQE2000)")(= ln16 "IA (NRE2000)")(= ln16 "IA (E2000)")(= ln16 "IA (CG3480 REMODEL)") (= ln16 "IA (E2000 REMODEL)")(= ln16 "IA (NEW YORK REMODEL)"))))
(PROGN
(COMMAND "-INSERT" "Sheet Info 24x36=H:/BL-LIB/Sheet Info 24x36.dwg" "y" "" "0,0" "1" "" "")
(COMMAND "ATTSYNC" "Name" "Sheet Info 24x36" "")
);END Progn
);END IF
(princ)
Also, one more thing. This program inserts the block & redefines it but i wonder if i should erase the last enity because i'm assuming this is placing another entity into my file
stevor
Although for prompts, try:
(setvar 'nomutt 0)
S
(setvar 'nomutt 0)
Does it matter what no mutt is set to in your drawing? I checked the drawing & nomutt was set to 0.
