Similar LISP not working
I Have 2 code, with the same structure but one works while the other doesn't (Unknown command) i'm really confused (cad12 and cad16 behave the same)
;;;---------------- Layer A-THICK --------------------   < this works
(DEFUN C:TYY (/ LAY)
  (COMMAND "-LAYER" "M" "A-THICK" "C" "33" "" "LW" "0.2" "" "")
  (PRINC)
(DEFUN C:TY () (ssget)
  (command "change" "p" "" "p" "la" "A-THICK" ""))
;;;---------------- Layer A-GLASS --------------------  < error "Unknown command"
(DEFUN C:KII (/ LAY)
  (COMMAND "-LAYER" "M" "A-GLASS" "C" "154" "" "LW" "0.09" "" "")
  (PRINC)
(DEFUN C:KI () (ssget)
  (command "change" "p" "" "p" "la" "A-GLASS" ""))
hmsilva
Hello kevlee91 and welcome to the Autodesk Community!
Try
(defun C:TYY nil
    (command "_.-layer" "_U" "A-THICK" "_T" "A-THICK" "_M" "A-THICK" "_C" "33" "" "_LW" "0.2" "" "")
    (princ)
(defun C:TY nil
    (if (ssget)
        (command "_.-layer" "_U" "A-THICK" "_T" "A-THICK" "_M" "A-THICK" "_C" "33" "" "_LW" "0.2" "" "" "_.change" "_P" "" "_P" "_LA" "A-THICK" "")
    (princ)
(defun C:KII nil
    (command "_.-layer" "_U" "A-GLASS" "_T" "A-GLASS" "_M" "A-GLASS" "_C" "154" "" "_LW" "0.09" "" "")
    (princ)
(defun C:KI nil
    (if (ssget)
        (command "_.-layer" "_U" "A-GLASS" "_T" "A-GLASS" "_M" "A-GLASS" "_C" "154" "" "_LW" "0.09" "" "" "_.change" "_P" "" "_P" "_LA" "A-GLASS" "")
    (princ)
Hope this helps,
Henrique
it still giving unknown command on "KI" and "KII"; "TY" and "TYY" still works
i'm putting all my LISP in acad2016doc.lsp file
hmsilva
acad2016doc.lsp file is reserved for AutoCAD!!!
Don't edit this file!!!
In notpad, or another text editor, put all your LISP's and seveas acaddoc.lsp, and AutoCAD will load it in hall dwg's.
EDIT: tested in AC2016, and everything worked as expected...
Hope this helps,
Henrique
oh, it works now
ty
hmsilva
@Anonymous wrote:
oh, it works now
ty
You're welcome, kevlee91
Glad I could help
Henrique
