Zoom-Jump to next vertex
ebsoares
Message 1 of 14
ebsoares
Hi, all.
Does anyone know of a routine where, while having a polyline/3dpoly/spline selected and having just edited one of its vertices, one would call such routine and it would jump/zoom to the next vertex, keeping the same view scale and the object still selected?
It would work great when having to re-edit an element with many vertices. We have to always zoom around and pan while doing this type of work...
Thanks in advance
Edgar
Replies (13)
Message 2 of 14
Kent1Cooper
How are you editing vertices?  Within PEDIT's Edit-vertex option?  Just grip-editing?  Stretch, perhaps?
Kent Cooper, AIA
Message 3 of 14
ebsoares
Hi, Kent.
No PEdit, just grip-editing. I select a pline (usually 3dpline, actually, but could be a spline as well) and, from a plan view (looking straight from above), move the grips to a more desirable location...
Message 4 of 14
ebsoares
Hi again.
I’ve been talking to one of our coworkers and we came with a sort of pseudocode that might help understand what the routine could go through. It’s already a little different from my original post because we think AutoCAD does not keep track of element edit history down to what vertex was edited last, aside from the undo/redo list.
Before calling the command, the element would already be highlighted.
Here’s the process:
. Call lisp command;
    . Get selected element;
    . Create list of vertex coordinates for that element (with their vertex numbers as well);
    . Prompt: “Click near current vertex”;
    . Get coordinate of click/pick pt;
    . Calculate difference (distance) from click pt’s coordinates to each vertex of selected element to find out closest vertex on element – that is the current vertex;
    . Get current vertex number;
    . Copy current zoom/view settings;
    . Zoom (or pan) to the next vertex (current + 1) using previous zoom/view settings;
    . Re-select element (if it’s not highlighted anymore);
. End lisp routine;
In bold and underlined are the two only interactions with the user - calling the command and clicking on the screen.
Attached is a small screenshot that might help visualize what’s going on.
Thanks one more time for any input.
Edgar
Message 5 of 14
Kent1Cooper
I think it could be fairly simple, but unfortunately what I was hoping would be the easiest way doesn't work as I had hoped.  When I grip-edit a Polyline, the location represented by "@" or (getvar 'lastpoint) is the place where the vertex was before, not the place where you move it to -- if it were the latter, it would be really easy.  But it raises the question:  How drastically are you re-positioning vertices?  If they're not being moved too far in relation to the geometry, a routine could probably find the closest point on the object to the "@" place [in lieu of the User needing to pick near the vertex], find which vertex is closest to that [assuming that's always still the one you just grip-edited], and Zoom-Center on the next vertex.
Kent Cooper, AIA
Message 6 of 14
marko_ribar
Here is my version... BTW. It has noting to do with gripediting but rather I used STRETCH command... Try it and see if you're satisfied...
(defun c:zvv ( / *error* ucsf es e pl p pp n )
  (vl-load-com)
  (defun *error* ( msg )
    (if ucsf
      (command "_.UCS" "_P")
    (if msg
      (prompt msg)
    (princ)
  (if (eq (getvar 'worlducs) 0)
    (progn
      (command "_.UCS" "_W")
      (setq ucsf t)
  (setq es (entsel "\nPick 2d curve with vertices to edit-stretch them..."))
  (setq e (car es))
  (command "_.ZOOM" "_C" "_non" (cadr es))
  (while (< 0 (getvar 'cmdactive)) (command ""))
  (prompt "\nZoom&edit vertex... ESC to finish...")
  (while t
    (cond
      ( (eq (cdr (assoc 0 (entget e))) "LWPOLYLINE")
        (setq pl (mapcar '(lambda ( p ) (trans (list (car p) (cadr p) (cdr (assoc 38 (entget e)))) e 0)) (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (eq (car x) 10)) (entget e)))))
      ( (eq (cdr (assoc 0 (entget e))) "POLYLINE")
        (setq v e)
        (while (setq v (entnext v))
          (if (eq (cdr (assoc 0 (entget v))) "VERTEX")
            (setq pl (cons (cdr (assoc 10 (entget v))) pl))
        (setq pl (reverse pl))
      ( (eq (cdr (assoc 0 (entget e))) "SPLINE")
        (setq pl (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (eq (car x) 10)) (entget e))))
      ( (or (eq (cdr (assoc 0 (entget e))) "ARC") (eq (cdr (assoc 0 (entget e))) "ELLIPSE") (eq (cdr (assoc 0 (entget e))) "LINE"))
        (setq pl (cons (vlax-curve-getendpoint e) pl) pl (cons (vlax-curve-getstartpoint e) pl))
    (if (null p)
      (progn
        (setq p (cadr (grread t)))
        (setq pl (vl-sort pl '(lambda ( a b ) (< (distance p a) (distance p b)))))
        (setq n 0)
      (repeat (setq n (1+ n))
        (setq pl (cdr (reverse (cons (car pl) (reverse pl)))))
    (setq pp (car pl))
    (command "_.ZOOM" "_C" "_non" pp)
    (command "_.STRETCH" "_CP" "_non" (mapcar '- pp (list (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0) (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0))) "_non" (mapcar '+ pp (list (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0) (- (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0)))) "_non" (mapcar '+ pp (list (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0) (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0))) "_non" (mapcar '+ pp (list (- (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0)) (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0))) "" "")
    (while (< 0 (getvar 'cmdactive)) (command "\\"))
  (princ)
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 7 of 14
marko_ribar
I had an issue with SPLINE, also some other fixes too... Now should work as desired... Test it...
(defun c:zvv ( / *error* ucsf es e pl ppl p pp n )
  (vl-load-com)
    (if ucsf
    (if msg
      (prompt msg)
    (princ)
    (progn
      (setq ucsf t)
  (setq e (car es))
  (while t
    (cond
        (setq v e)
        (setq pl (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (eq (car x) 11)) (entget e))))
    (if (null p)
      (progn
        (setq p (cadr es))
        (setq ppl (vl-sort pl '(lambda ( a b ) (< (distance p a) (distance p b)))))
        (setq n (vl-position (car ppl) pl))
      (repeat (setq n (rem (1+ n) (length pl)))
    (if (null pp)
      (setq pp (car ppl))
      (setq pp (car pl))
  (princ)
Message 8 of 14
marko_ribar
WHY THIS ISN'T ACCEPTED AS A SOLUTION?
(defun c:zvv ( / *error* getinfo ucsf es e pl ppl p pp n 10px )
  (vl-load-com)
    (if ucsf
    (if msg
      (prompt msg)
    (princ)
  (defun getinfo ( es )
    (setq e (car es))
    (cond
        es
        (setq v e)
        es
        es
        (if (not (equal (car pl) (cadr pl) 1e-8))
          es
          (progn
            (prompt "\nWrong entity pick...")
            (setq es (getinfo es))
      ( t
    (progn
      (setq ucsf t)
  (setq e (car es))
  (print)
  (while (and es (setq es (getinfo es)))
    (if (null p)
      (progn
        (setq p (cadr es))
    (if (null pp)
      (setq pp (car ppl))
      (setq pp (car pl))
    (setq 10px (* (/ (getvar 'viewsize) (cadr (getvar 'screensize))) 10.0))
    (command "_.STRETCH" "_CP" "_non" (mapcar '- pp (list 10px 10px)) "_non" (mapcar '+ pp (list 10px (- 10px))) "_non" (mapcar '+ pp (list 10px 10px)) "_non" (mapcar '+ pp (list (- 10px) 10px)) "" "")
  (princ)
M.R.
Message 9 of 14
ebsoares
Hi, Marko.
Thanks for the routine you've put together, it works fantastic!
I was wondering if you could implement 3D polylines (it didn't work with them when I tried) and an option to skip editing (suppose we don't need to edit the vertex we're zoomed in to).
Thanks again,
Edgar
Message 10 of 14
marko_ribar
I was busy, but I thought you'd figure it... I forgot to nil pl variable inside (getinfo) at the beginning of subfunction...
Here, test it now... (Isn't this a solution?)
  (vl-load-com)
    (if ucsf
    (if msg
      (prompt msg)
    (princ)
    (setq e (car es) pl nil)
    (cond
        es
        (setq v e)
        es
        es
          es
          (progn
      ( t
    (progn
      (setq ucsf t)
  (setq e (car es))
  (print)
    (if (null p)
      (progn
        (setq p (cadr es))
    (if (null pp)
      (setq pp (car ppl))
      (setq pp (car pl))
  (princ)
HTH, M.R.
Message 11 of 14
marko_ribar
Oh, I see now... You want to perform this action from 3D VIEW... Try this, use @ character to skip to next vertex...
(defun c:zvv ( / *error* getinfo ucsf es e pl ppl p pp n )
  (vl-load-com)
    (if ucsf
    (if msg
      (prompt msg)
    (princ)
    (cond
        es
        (setq v e)
        es
        es
          es
          (progn
      ( t
    (progn
      (setq ucsf t)
  (setq e (car es))
  (print)
  (prompt "\nZoom&edit vertex... To skip to next vertex - type \"@\" character... ESC to finish...")
    (if (null p)
      (progn
        (setq p (cadr es))
    (if (null pp)
      (setq pp (car ppl))
      (setq pp (car pl))
    (command "_.STRETCH" "_C" "_non" pp "_non" pp "" "")
  (princ)
I think that's it... This should be your solution by me...
HTH, M.R.
Message 12 of 14
ebsoares
Marko, this is great work.
Thank you very much for the time you put into this.
Edgar
Message 13 of 14
ebsoares
Hi, Marko.
I just realized this. As I'm editing an element, if we change the view (zoom in, or out, or pan) then the routine will disregard the edit...
Message 14 of 14
ebsoares
Hi, Marko. Never mind, it seems to be working now. Go figure...
Thanks again,
Edgar
