NENTSEL to SSGET
NENTSEL to SSGET
msarqui
Message 1 of 11
NENTSEL to SSGET
msarqui
Hi guys,
May I have some help please?
I am struggling with this problem. I am trying to adapt an existing routine that uses NENTSEL to work with StripMtexthttps://cadabyss.wordpress.com/2010/01/04/stripmtext-v5-0/
So this works:
(if (setq sel (ssget)) (StripMtext sel "C"))
But this not works because the NENTSEL in my existing routine does not put the selected objects to accept a PREVIOUS selection.
(setq nsel (nentsel))
(if (setq sel (ssget "_P")) (StripMtext sel "C"))
So, how to put the object selected by NENTSEL in a SSGET selection?
Marcelo
Replies (10)
Message 2 of 11
Satoews
USE SSADD TO ADD TO SEL
SSADD
Shawn T
Message 3 of 11
Satoews
(ssadd (cdr (entget (ssname nsel 1))) sel)
Try this, untested but I think I got this right, if not and someone dosen't get to it first, I will work it over tonight.
Shawn T
Message 4 of 11
msarqui
Hi Shawn, thanks for the repply.
I am having an error here
Error: bad argument type: lselsetp (<Entity name: 7ffff96da80> (228.467 194.123 0.0))
Message 5 of 11
Satoews
(ssadd (ssname nsel 0) sel)
this worked for me, try it out.
Shawn T
Message 6 of 11
msarqui
Same error.
Atached the block I am using. Maybe it could help.
Thanks.
Message 7 of 11
hmsilva
@msarqui wrote:
Hi guys,
So this works:
Marcelo
Hi Marcelo,
why 'nentsel'???
Edit: try this...
(if (and (setq nsel (nentsel "\nSelect an attribute: "))
         (= (length nsel) 2)
         (setq ent1 (entget (car nsel)))
         (= (cdr (assoc 0 ent1)) "ATTRIB")
         (setq hnd1 (cdr (assoc 330 ent1)))
   (progn
      (setq ss (ssadd))
      (setq ss (ssadd hnd1 ss))
      (StripMtext ss "C")
Hope this helps,
Henrique
Message 8 of 11
msarqui
@hmsilva wrote:
Hi Marcelo,
why 'nentsel'???
Henrique
Hi Henrique, as I said, I am trying to adapt an old routine that uses NENTSEL...
If the answer exists and if it is simple, I think it will be far less work than rewrite the entire existing routine.
Message 9 of 11
Satoews
(ssadd (car nsel) sel)
I think i fixed mine but hsilva knows way more than i do =P
Shawn T
Message 10 of 11
msarqui
It is perfect!
Many thanks Henrique!
Message 11 of 11
hmsilva
@msarqui wrote:
It is perfect!
You're welcome, Marcelo!
Glad I could help
Henrique
