Show Distance between two lines at fixed interval
Message 1 of 27
I have a project where a cable is laid along a road. I need to show the perpendicular distance of the cable from the road centerline at every 10m interval. I cannot do it manually as the cable length is in 100s of kms. I have been using autocad for a long time but am new to LISP.
Is there a LISP code that can do this?
Please help.
Replies (26)
Message 2 of 27
devitg
Yes, it could be possible . Please upload a dwg sample .
Message 3 of 27
Thanks for the reply devitg. PFA the sample drawing.
I have put chainage on the cable route (red line). The black line is the road centerline. I need the perpendicular distance from the cable to the road centerline at every 10m. I have done it for the first four chainage points (from 00+000 t0 00+040) points manually to make it clear.
Message 4 of 27
ВeekeeCZ
Try this routine
Spoiler
(vl-load-com)
(defun c:DimPl2Pl ( / en1 en2 int len stt len pt1 pt2)
  (if (and (setq en1 (car (entsel "\nSelect 1st polyline (dim from): ")))
	   (= "LWPOLYLINE" (cdr (assoc 0 (entget en1))))
	   (setq en2 (car (entsel "\nSelect 2nd polyline (dim to): ")))
	   (= "LWPOLYLINE" (cdr (assoc 0 (entget en2))))
	   (setq int (getdist "\nInterval: "))
	   (setq len (vlax-curve-getDistAtParam en1 (vlax-curve-getEndParam en1)))
	   (not (initget 4))
	   (setq stt (cond ((getreal "\nDistance at the beginning <0>: "))
			   (0)))
	   (not (initget 4))
	   (setq len (cond ((getreal (strcat "\nDistance at the end <along the entire polyline = " (rtos len 2 2) ">: ")))
			   (len)))
    (while (and (<= stt len)
		(setq pt1 (vlax-curve-getPointAtDist en1 stt))
		(setq pt2 (vlax-curve-getClosestPointTo en2 pt1)))
      (command "_.DIMALIGNED"
	       "_none" (trans pt1 0 1)
	       "_none" (trans pt2 0 1)
	       "_none" (polar (trans pt1 0 1)
			      (+ (* 1.5 pi)
				 (angle (trans pt1 0 1) (trans pt2 0 1)))
			      1.5))
      (setq stt (if (= stt (min (+ stt int) 	; if next point is beyond the end length
				len))
		  (+ stt int)			; then use that it because which (while) does not pass
		  (min (+ stt int)		; else use middle point or max
		       len))))
    (princ "\nWrong selection. Two LWPolylines are required.")
  (princ)
- make sure that the first polyline (which on would be applied the interval) is in the correct direction - in your sample is NOT!
- make sure that the both polylines are correctly joined (the second polyline in your sample is NOT)
- i would recommend flat both (3d)polylines to polylines
- I think the better result you'll get if you would dimension from the cable line, not from the axis (at least at some parts.. - dim is put at the clostest point on second polyline).
Sorry @devitg, I hope you don't mind. I just quickly adjusted some older routine of mine.
Message 5 of 27
Thanks BeeKeeCZ! This is exactly what i wanted. Thanks for pointing out the blind spots. I will remember to merge the polylines before applying it.
Thanks a ton!! 🙂
Message 6 of 27
devitg
Hi BeekeeCZ , do noy worry , all help is wellcome , I just ask the OP to upload the DWG.
All poster think that with words, they can get answer .
Seem to be they think  this forum is a ORACLE " A person considered to be a source of wise counsel or prophetic opinions."
Or in a rude way "NO CORPSE, NO COFFIN"
Message 7 of 27
Hey BeekeeCZ, I was attempting to modify your code you created here.
I was attempting to modify it where it found a line perpendicular off of the first line you select, but keep running into a wall. See screenshot for intent.
Would appreciate any direction, thanks!
(if (and (setq en1 (car (entsel "\nSelect polyline to dimension from: ")))
	   (setq en2 (car (entsel "\nSelect polyline to dimension to: ")))
	   (setq int (getdist "\nSpecify spacing interval: "))
	   (not (initget 4))
	   (setq stt (cond ((getdist "\nSpecify offset from beginning <0>: ")) (0)))
	   (not (initget 4))
	   (setq len (cond ((getdist (strcat "\nSpecigy length of path to use for measurement <" (if (= (getvar 'measurement) 0) (rtos len 4 5) (rtos len 2 2)) ">: "))) (len)))
		(setq pt2 (vlax-curve-getPointAtDist en1 int))
		(setq pt3 (polar (trans pt1 0 1) (+ (/ pi 2) (angle (trans pt1 0 1) (trans pt2 0 1))) 1.5))
		(setq pt4 (vlax-curve-getPointAtDist en2 stt))
		(setq pt5 (vlax-curve-getPointAtDist en2 int))
		(setq pt6 (inters pt1 pt3 pt4 pt5 nil))
	       "_none" (trans pt6 0 1)
		   "_none" (polar (trans pt1 0 1) (+ (* 1.5 pi) (angle (trans pt1 0 1) (trans pt6 0 1))) 1.5))
				len))
		  (+ stt int)			; then use the beyond len which (while) does not pass
		       len))))
    (princ "\nError. Two polylines are required.")
Message 8 of 27
ВeekeeCZ
Next time post the entire code and some test dwg.
My approach would be:
(foreach pnt on pl1
 - get angle (vector of pl) at pnt using: (angle '(0 0 0) (vlax-curve-getFirstDeriv path pnt))))
 - entmakex templine, example HERE
 - find all intersection points tmp vs. pl2 using the intesectwith method, example HERE
 - if there is (are) any int-pnts, draw dim
 - erase templine)
Good luck
Message 9 of 27
brodie.mclean
Hey,
I know this is an old thread, but i'm wondering if this code can be modified to dimension from an Alignment to a Corridor Created Feature Line?
Brodie
Message 10 of 27
devitg
Please upload your sample.dwg
Message 11 of 27
brodie.mclean
Sorry my sample drawing has short-cut data and can't be uploaded.
Here's the jist:
- I have an alignment from which I have created a corridor from that has varying widths.
- From the corridor i created a linked feature line
- I now want to auto-dimension between the Alignment and Feature line at a specified interval.
Message 12 of 27
brodie.mclean
Here's a dwg showing what I'm after.
Message 13 of 27
devitg
@brodie.mclean , please check the dwg , there aren't any alignment  , and  the feature line from corridor
Either it is in true size, od scale 1:1
Message 14 of 27
Sea-Haven
This appears to be a CSD dwg going by the layer names, have you looked at the peg/shift option in the CSD road software.
Message 15 of 27
brodie.mclean
It's a civil3d drawing. Are you opening it Civil? it' shows up correctly on my computer.
Message 16 of 27
devitg
@brodie.mclean , hi . No. I use ACAD 2018. Please save as to ACAD 2018
Message 17 of 27
brodie.mclean
Does this work?
Message 18 of 27
devitg
@brodie.mclean , no way. Sorry
Despite it line length, differs a lot from real
Message 19 of 27
Sea-Haven
Civ3d will make alignments as proxy objects in Autocad.so will not have access.
Message 20 of 27
brodie.mclean
Here a jist of what I'm looking for in a picture then..
