Show Distance between two lines at fixed interval
Message 1 of 27
I have a project where a cable is laid along a road. I need to show the perpendicular distance of the cable from the road centerline at every 10m interval. I cannot do it manually as the cable length is in 100s of kms. I have been using autocad for a long time but am new to LISP.
Is there a LISP code that can do this?
Please help.
Replies (26)
Message 21 of 27
devitg
@brodie.mclean Maybe . like it ?
Message 22 of 27
brodie.mclean
Yes, something like this is what I'm looking for.
Message 23 of 27
I hate to revive a dead thread but I was wondering how I could add text to the annotation such as "proposed R/L" or even just R/L. Preferably asking for a prompt that the user can specify the text each time. I know how to enter it manually in text properties but Want to make it more efficient.
Thank you in advance.
Message 24 of 27
Sea-Haven
Post sample dwg so explains what you want
Message 25 of 27
I have worked on the code since asking my question and I think I'm almost there. this is what I have right now.
(vl-load-com)
(defun c:AUTODIM ( / en1 en2 int len stt len pt1 pt2 prefix linty new dim newdimvalue)
(if (and (setq en1 (car (entsel "\nSelect 1st polyline (dim from): ")))
(= "LWPOLYLINE" (cdr (assoc 0 (entget en1))))
(setq en2 (car (entsel "\nSelect 2nd polyline (dim to): ")))
(= "LWPOLYLINE" (cdr (assoc 0 (entget en2))))
(setq int (getdist "\nInterval: "))
(setq len (vlax-curve-getDistAtParam en1 (vlax-curve-getEndParam en1)))
(not (initget 4))
(setq stt (cond ((getreal "\nDistance at the beginning <0>: "))
(0)))
(not (initget 4))
(setq len (cond ((getreal (strcat "\nDistance at the end <Use the entire polyline = " (rtos len 2 2) ">: ")))
(len)))
(setq prefix "<>' ")
(setq linty (cond ((getstring T "\nWhat are you measuring to? <R/W>: "))
("R/W")))
(while (and (<= stt len)
(setq pt1 (vlax-curve-getPointAtDist en1 stt))
(setq pt2 (vlax-curve-getClosestPointTo en2 pt1)))
(command-s "_.DIMALIGNED"
"_none" (trans pt1 0 1)
"_none" (trans pt2 0 1)
"_none" (polar (trans pt1 0 1)
(+ (* 1.5 pi)
(angle (trans pt1 0 1) (trans pt2 0 1)))
1.5))
(setq newdim (entlast))
(setq newdimvalue (strcat prefix linty))
(command "dimedit" "n" newdimvalue newdim "")
(setq stt (if (= stt (min (+ stt int) ; if next point is beyond the end length
len))
(+ stt int) ; then use the beyond len which (while) does not pass
(min (+ stt int) ; else use middle point or max
len))))
(princ "\nWrong selection. Two LWPolylines are required.")
(princ)
My issue right now is that I would like to round the dimension to the nearest .5 and change the comma in the result to a decimal point. Also, when I don't input a string for my notation, rather than the R/W printing it just adds the footage mark.
Thank you for the swift reply.
Message 26 of 27
ВeekeeCZ
I've fixed the last one. The others are driven by your dimstyle.
(vl-load-com)
	   (not (initget 4))
			   (0)))
	   (not (initget 4))
			   (len)))
	   (setq linty (getstring T "\nWhat are you measuring to? <R/W>: "))
	   (setq linty (if (= linty "") "R/W" linty))
		       (+ (* 1.5 pi)
		       1.5))
				len))
		       len))))
  (princ)
Message 27 of 27
stevor
A conventional offset distance is along a normal line from your reference line,
so a few more steps would be needed.
S
