setvar "select locked layer" impossible?
sander.van.pelt
sander.van.pelt
Hello all,
I have a drawing with multiple external references that are all locked. If I want to select something, I quickly select an xref when I create a selection window.
But also other layers that may be locked.
Wasn't there a variable that allowed you to set whether or not you could select a locked layer? So that it does not light up/appear dotted (Selection effect variable) when you select this locked layer/xref.
So you must first unlock it in your layer properties manager or with the _lyulk command if you want to select it again.
ВeekeeCZ
This add-on can be used for XREFs. It has options to make XREFs visible, selectable, and/or snappable. It's independent of the lock feature.
https://apps.autodesk.com/ACD/en/Detail/Index?id=6784178835292008697&appLang=en&os=Win32_64
AFAIK there is no app for locked layers in general. And certainly not a built-in sysvar.
Kent1Cooper
Do a Search in this Forum and/or the regular AutoCAD Forum.  This topic has come up many times.
Kent Cooper, AIA
sander.van.pelt
Hello @Kent1Cooper,
Sorry, but I could find many similar questions, but without solutions. I will search the forum again.
This post may therefore be removed.
Could you perhaps take a look at my personal message that I sent you on June 10? This concerns your "AlignSnapAng.lsp" from 2013, which I have been using for years, but no longer works as it should.
Thank you for that
cadffm
@sander.van.pelt  schrieb: but no longer works as it should.
It generally works! If you have trouble with a partial situation(Command/Objecttype/filesettings), upload a sample .dwg with just one sample object in the right thread and tell more about the issue.
Sebastian
