setting the position of a visibility parameter in a dynamic block
GeeHaa
GeeHaa
I need to change the position of a visibility Parameter Triangle in about 100 blocks. I tried enget on the name of the Visibility parameter while in the block editor but it seems to be a dead end. If someone could point me where to look it would be appreciated.
Thanks in advance
jwhite
If you use (setq obj (vlax-ename->vla-object (car (entsel)))) and then look at the object properties it has a base point you can use. Maybe filter a selection set list by ObjectName?
GeeHaa
Yes. This is just what I needed.
Thank You.
