How to create a list which the user can search?
I currently have a LISP routine with a DCL dialog that is used to specify the merchandise on a fixture. Currently, the DCL has a drop-down box which you use to select the merchandise from a list -- however this list is becoming painfully long (even after being split into departments).
With the current setup, if you are looking for "Milk_2%" you can type "M" in the dialog and it will jump to the first M term. However, if you type in "Mi" it will jump to the first "M" term, and then jump to the first "I" term. With thousands of fixtures per store, and a merchandise list with 80 items per letter at times, being able to search deeper than the first letter would save us a TON of time.
I'm completely OK with a solution that has the user select the merchandise from the command line, or some other interface (if there are any?). Any advice would be greatly appreciated!
DannyNL
With so many items I would probably use a listbox instead of a dropdown with an additional textbox to input your search string. With every input in the search field you could change the contents of the listbox to only those that have a match so decreasing the number of items in the listbox or maybe jump to the first item in the listbox that has a match.
It seems so obvious now.. Thank you for the help Danny!
DannyNL
Glad I could help Smiley Happy
