Save Selection of objects as DXF
Hi everyone,
I'm trying to create a macro to export selected objects as DXF to the same folder as the main drawing.
In previous versions of AutoCAD it used to work fine, all I needed to do was selecting the source point and write the name of the final file to be saved but when I tried this with 2018 I can only save with the same name as original drawing..If I write another name it won't work.
I cant see what I'm doing wrong, any help would be much appreciated.
This is the code:
^C^C_dynpicoords;1;_undo;_m;_select;_auto;\_move;_p;;\0,0;_move;_p;;0,0,0;@0,0,1e99;move;_p;;0,0,0;@0,0,-1e99;_zoom;_o;_p;;-overkill;_p;;_p;_n;_i;_c;_d;_dxfout;\V;R12;O;_p ;16;_undo;_b;
Thanks1-SELECT OBJECTS1-SELECT OBJECTS2-SELECT SOURCE POINT2-SELECT SOURCE POINT3-SPECIFY NAME3-SPECIFY NAME4-WON'T SAVE ANYTHING WITH A DIFFERENT NAME FROM THE ORIGINAL FILE.4-WON'T SAVE ANYTHING WITH A DIFFERENT NAME FROM THE ORIGINAL FILE.
paullimapa
Hm..I did not encounter any problems.
You can try and see what happens at the command line if you used lisp this to invoke the command:
(command"dxfout")
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Did you try to give a different name from the original file?
It works if I use the same name as original file, otherwise gives me an error.
In this case I'm trying to save as  "ddddd"
Command: _dynpicoords
Enter new value for DYNPICOORDS <1>: 1
Command: _undo
Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: _m
Command: _select
Select objects: _auto
Select objects: Specify opposite corner: 3 found
Select objects:
Command: _move
Select objects: _p
3 found
Select objects:
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>: 0,0
Command: _move
Select objects: _p
3 found
Select objects:
Specify base point or [Displacement] <Displacement>: 0,0,0
Specify second point or <use first point as displacement>: @0,0,1e99
Command: move
Select objects: _p
3 found
Select objects:
Specify second point or <use first point as displacement>: @0,0,-1e99
Command: _zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _o
Select objects: _p
3 found
Select objects:
Command: -overkill
Select objects: _p
3 found
Select objects:
Current settings: Tolerance=0.000001, Ignore=Color, Optimize polylines=No, Combine partial overlap=Yes, Combine end-to-end=Yes
Enter an option to change [Done/Ignore/tOlerance/optimize Plines/combine parTial overlap/combine Endtoend/Associativity] <done>: _p
Optimize segments within plines [segment wiDth/Break polyline/Yes/No] <No>:_n
Enter an option to change [Done/Ignore/tOlerance/optimize Plines/combine parTial overlap/combine Endtoend/Associativity] <done>: _i
Specify properties to ignore when comparing objects...
[None/All/ Color/LAyer/Ltype/ ltScale/LWeight/Thickness/TRansparency/plotSTyle/Material] <Color>:_c
Enter an option to change [Done/Ignore/tOlerance/optimize Plines/combine parTial overlap/combine Endtoend/Associativity] <done>: _d
0 duplicate(s) deleted
0 overlapping object(s) or segment(s) deleted
Command: _dxfout
Enter DXF file name <A:\Library\TCL Blocks.dxf>: ddddd
Current DXF settings: Precision= 16 Format= ASCII Preview= No Version= 2018
Enter decimal places of accuracy (0 to 16) or [Binary/select Objects/Preview/Version] <16>: V
Enter version [R12(LT2)/2000(LT2000)/2004(LT2004)/2007(LT2007)/2010(LT2010)/2013(LT2013)/2018(LT2018)] <2018>: R12
Enter decimal places of accuracy (0 to 16) or [Binary/select Objects/Preview/Version] <16>: O
Select objects: _p 3 found
Select objects:
Enter decimal places of accuracy (0 to 16) or [Binary/Preview/Version] <16>: 16
Error: DXFOUT aborted
Command: _undo
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: _b
DXFOUT -OVERKILL ZOOM MOVE MOVE MOVE SELECT
Mark encountered
me but if I want to save with a different one won't work.
