Setting and using the command measure as a variable
sgutierrezLK2GY
Message 1 of 8
sgutierrezLK2GY
Hello
I am new to the Lisp feature in AutoCAD. but I was wondering how can I set a variable to equal the measure function between two lines.
Then divide that variable in 2 and then create an offset of one of the lines at that distances or value.
Example:
take this value, devide it by 2
and the new value set it as offset value and create an offset in the middle of both lines.
so the end result looks like this
Replies (7)
Message 2 of 8
cadffm
sorry to say, but my opinion is you have to learn the basics first.
how to math, how to get data and then you can start with simple tasks.
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-C64046FA-CD9E-4B38-9967-A501119E4A62
https://www.afralisp.net/autolisp/tutorials/index.php?category_id=1
SETQ GETPOINT GETDIST DISTANCE CAR ENTSEL and a lot more functions..
! For this goal, you don't need Lisp*, but you can use it..
AND: You will find a lot of ready codes to offset to the half distance.
Sebastian
Message 3 of 8
sgutierrezLK2GY
then you are telling me that the solution is very simples. as long as you know the basics??
also thank you for the links, have been struggling to find these kind of information 😄
Message 4 of 8
ВeekeeCZ
Here's the motivation for you.
(vl-load-com)
(defun c:midset ( / e p r)
  (if (and (setq e (entsel "\nSelect line to offset: "))
	   (setq p (vlax-curve-getclosestpointto (car e) (cadr e)))
	   (setq r (entsel "\nSelect reference line: "))
	   (setq r (vlax-curve-getclosestpointto (car r) (cadr r)))
	   (setvar 'offsetdist (/ (distance p r) 2))
    (command "_.offset" "" e "_non" r ""))
  (princ)
Agreed with @cadffm , learn a few basic functions and you can make wonders.
Message 5 of 8
cadffm
hmm. If you don't want a fully rebuilt of the native offset command, and if you just want to controle the native offset command, then yes.
Without Lisp (or just using a simple (command statement), you can create a macro like this:
start COMMAND OFFSET
use THROUGH option
select the object to offset
start object selection method m2p
start object selection _nea
use @ for the last point
start object selection _per
and select the other object
exit offset command
well done.
Sample: ^C^C^C_.OFFSET;_through;\_m2p;_nea;@;_per;\;
sure, by Lisp you can do the same, a bit more "bullet proof"
Here is the Lisp board (it's for questions about programming tips & tricks) : Click!
Sebastian
Message 6 of 8
paullimapa
For this simple procedure you can use the built in AutoCAD object snap M2P aka Mid Between 2 Points
Paul Li
IT Specialist
@The Office
Message 7 of 8
paullimapa
try this after you enter the Offset command at the command prompt:
(/(getdist"\nEnter Measurement To Be Divided By 2")2)
Paul Li
IT Specialist
@The Office
Message 8 of 8
Kent1Cooper
@cadffm wrote:
.... AND: You will find a lot of ready codes to offset to the half distance.
There are whole topics on the subject, some with multiple approaches and variants, such as >this<.
Kent Cooper, AIA
