Pasting LISP commands inconsistent behavior
jo2ny
jo2ny
I attached a video screen capture describing the issue below.
I have two files:
File 1 containing:
(command "line" "0.000000,0.000000" "0.812800,0.067733" "")
(command "line" "0.000000,0.000000" "1.117600,-0.571500" "")
These lines represent an initial geometry.
File 2 containing:
(command "line" "0.050625,-0.050774" "0.812800,0.012740" "")
(command "line" "0.050625,-0.050774" "1.117600,-0.526030" "")
These lines represent the final geometry (obtained after a conversion algorithm).
The objective is to have the initial geometry and the final geometry in the same acad file drawn wish 2 distinct colors.
To do this I open a new acad file, copy file 1 contents and paste them in the command line.
I get 2 lines starting in (0,0) .
I change the layer color to , say, green.
I copy file 2 contents and paste them in the command line, and I get another two (green) lines, but they are not drawn in the correct coordinates.
They both start at (0,0). One ends in it's correct point (1.117600,-0.526030). The other one ends in a point as the previous copy-paste command which is wrong and unexpected. Also the starting point of (0,0) for the green lines is unexpected.
Why is this happening? Am I doing something wrong?
P.S.
I checked in the command line and the second paste had the coordinates correct. ( => not a clipboard issue)
As a workaround for this I found out that if I can paste the file2 contents in a new file and then base point copy them in the original file.
ВeekeeCZ
You need to turn off osnaps.
Prob best way is setting osnapcoord 1.
jo2ny
Wow, awesome, works like a charm!
This made my day, many thanks!
