Set layout with initget
EnM4st3r
Message 1 of 20
EnM4st3r
Hi, I want to select a Layout using initget.
I wrote the following function to do that for me. Its working when there are no spaces within the Layoutname but if there are spaces in it, for example "A0 - view A", then it does not work.
Any suggestions?
(defun setlayout (/ list2String) ; checks if its in Model area, if so, asks the user to change
   (if (= (getvar "ctab") "Model")
    (progn
      (defun list2String (lst space / str)
        (setq str (car lst))
        (foreach itm (cdr lst)
          (setq str (strcat str space itm))
        str
      (initget 1 (list2String (layoutlist) " "))
      (setvar "ctab" (getkword (strcat "Select Layout [" (list2String (layoutlist) "/") "]: ")))
);defun
Replies (19)
Message 2 of 20
ВeekeeCZ
I would use numbers... like this.
(progn (initget "1 2 3") (getkword "Select [1:Layout-a/2:Lay/3:Layout1]: "))
See the attached routine to see this example in code.
Message 3 of 20
Kent1Cooper
Keywords cannot have spaces in them, because a space is the delimiter between keywords in a single string in an (initget) function.
Kent Cooper, AIA
Message 4 of 20
EnM4st3r
yes, thats the problem..
went with @ВeekeeCZ suggestion and thats my result now:
(defun setlayout (/ lst) ; checks if its in Model area, if so, asks the user to change
  (setq lst (layoutlist))
    (progn
      (initget 1 (substr (apply 'strcat (mapcar '(lambda (x) (strcat " " (itoa (vl-position x lst)))) lst)) 2))
      (setvar "ctab" (nth (atoi (getkword (strcat "Select Layout [" (substr (apply 'strcat (mapcar '(lambda (x) (strcat "/" (itoa (vl-position x lst)) ":" x)) lst)) 2) "]: "))) lst))
);defun
Message 5 of 20
ВeekeeCZ
FYI
(layoutlist) returns a list of layouts in order of creation. If you wanna have them sorted in current order, use something like this
;; layouts in order
  (defun :layouts-in-order (/ l) ; pbejse https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layout-order/td-p/3749964
    (vlax-for o (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
      (setq l (cons (list (vla-get-name o) (vla-get-taborder o)) l)))
    (mapcar 'car (cdr (vl-sort l '(lambda (a b) (< (cadr a) (cadr b)))))))
Message 6 of 20
komondormrex
not in order of creation, but in strings sorting order to be precise.
Message 7 of 20
Sea-Haven
This is a GOTO but uses numbers like GOTO layout 12. Needs multi getvals.lsp as pops a dcl for layout number, save in a support path or change (if (not AH:getvalsm)(load "Multi Getvals.lsp")) to include full path of file use "\\". Hint 99 will go to last 0 goes to model.
Message 8 of 20
komondormrex
actually they could, see the gif.
Message 9 of 20
ВeekeeCZ
Ohh, come on! They can't. Period.
As you know, in this case of yours are keywords actually just those numbers.
Message 10 of 20
komondormrex
Period.
it is comma)
not at all.
Message 11 of 20
ВeekeeCZ
Ok, nice. Looks cool!
Hey, I have 4 layouts:
AA 1
AA 2
BB 1
BB 2
I would like to pick them in the same fashion as you did. Just typing: aa 2
And please, drop those initial numbers of yours, just wasted space.
So the prompt would look like this:
Select layout [AA 1/AA 2/BB 1/ BB 2]:
Thx!
Message 12 of 20
komondormrex
@ВeekeeCZ
i said it is a comma not ellipsis and show that it is possible to get layout set even if it has spaces in its name using kw. that's it.
Message 13 of 20
ВeekeeCZ
Well, I can imagine that your trick might be useful for some partial cases... but this seems too much to me.
Denying the claim that a keyword can contain a space is fundamentally wrong. Because if we accept it, we will create 2 keywords. Period.
Have fun!
Message 14 of 20
komondormrex
you know, that one is the case. btw you can not set active layout with spaced name with the solution of yours or i am missing something?
Message 15 of 20
ВeekeeCZ
Not sure what you mean.
(progn (initget "1 2 3") (getkword "Select [1:Layout bbb/2:Lay/3:Layout aaa]: "))
You can pick it by a mouse, you can type the highlighted number. Cannot type the name itself. That's the limitation... but spaces are not limited.
Your example... I don't like it because it presents something that it's not ready for. Say I don't realize that I have AA twice. So I start typing AA... then I would need to pick from 2 options... it should narrow it down.... but it's not... it's a dead end.
Message 16 of 20
komondormrex
was caddy glitch i think, returned nil a couple of times. now works with exception of setting a layout from drop down list.
upd.
not a glitch as i thought. it works not if i stay not in a model tab.
Message 17 of 20
ВeekeeCZ
OK, I see.
Never thought of that testing. We don't use it. Good to know.
Message 18 of 20
Sea-Haven
So for a dynamic initget using (layoutlist)
(defun c:laygo ( / lays)
(setq lays (layoutlist))
(setq lays (cons "Please choose " lays))
(if (not AH:Butts)(load "Multi radio buttons.lsp"))
(setq ans (ah:butts 1 "V" lays))
(setvar 'ctab ans)
(princ)
 Or if you have lots of layouts the above supports about 20 layouts max.
(defun c:layl ( / lays but)
(if (not AHlstbox)(load "Listbox-AH.lsp"))
(setq but (ahlstbox "Pick a layout" lays 20 10))
(setvar 'ctab (nth but lays))
(princ)
Message 19 of 20
ВeekeeCZ
Ok, tied some generic solution with minimum necessary translation. Seems good enough to me. Some issues obvious to you? Alternatively, post a solution that you consider better.
(layoutlist) is just for example.
(defun c:LayoutListPickable ( / lst lst-key)
  (setq lst-key (mapcar '(lambda (x / n) (cons (strcat (if (< (setq n (vl-position x lst)) 10) "0" "") (itoa n) ":" (vl-string-translate " ()[]<>/" "-{}{}{}|" x)) x)) lst))
  (initget 1 (substr (apply 'strcat (mapcar '(lambda (x) (strcat " " (car x))) lst-key)) 2))
  (setvar 'ctab (cdr (assoc (getkword (strcat "Select Layout [" (substr (apply 'strcat (mapcar '(lambda (x) (strcat "/" (car x))) lst-key)) 2) "]: ")) lst-key)))
  (princ)
Message 20 of 20
EnM4st3r
thx, this one is nice 👍
