semantic error
semantic error
Message 1 of 12
semantic error
hey
after i successfully load the lisp i need
when i type the command of the lisp
it says semantic error in dcl
and i donot know what to do
tried to see a solution in many places but it didnot work for me
so please help me with full explaination and all details to solve this problem to me
Replies (11)
Message 2 of 12
paullimapa
I assume you downloaded this from the website:
http://www.steel-link.com/downloads/download-detail.cfm?recordID=145
The files need to be placed into a folder called:
C:\STL
Then you need to add this into AutoCAD's Support Search path:
Options
Files tab
Support File Search Path
Add C:\STL
Then enter:
(load"STL")
Now it should work when you enter command: STL
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 12
i did what you said exactly
still says semantic error
Message 4 of 12
note
i was using visual lisp
and i found this notepad created on my desktop
this was written in it
====== DCL semantic audit of c:/stl/stl ======
Hint in "stl_ersa". (widget type = list_box, key = "TABLE_ERSA")
height = 13 is probably redundant.
i donot know what is this related to
Message 5 of 12
paullimapa
What version of AutoCAD are you running?
I have no problems running on vanilla AutoCAD 2015, 2017 & 2018.
After I enter (load"STL") I get the attached publisher warning dialog so I would click Always Load.
Then when I enter STL I get the attached STL AutoCAD Draughting Utility window.
Paul Li
IT Specialist
@The Office
Message 6 of 12
paullimapa
You can always remove the height line but that should not be causing the error you are getting.
Paul Li
IT Specialist
@The Office
Message 7 of 12
iam using autocad 2018
right now i managed to load lisp
and when i write the command stl
this is what i get from command bar
Command: STL
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Message 8 of 12
paullimapa
Doing a search on-line matching your error message I found these links that mentions of other vertical add-on apps with error trap functions that may be the culprit. But other than that I have no solutions for you. Perhaps others may have encountered something similar that can give you a better solution.
http://architects-desktop.blogspot.com/2014/11/aca-2015-cannot-invoke-command-from.html
https://forums.autodesk.com/t5/autocad-architecture-forum/cannot-invoke-command-from-error-without/t...
http://www.cadtutor.net/forum/showthread.php?87670-Error-message-when-trying-to-load-up-a-*error*-fu...
Perhaps you could check to make sure you are running AutoCAD and not one of the AutoCAD verticals?
Paul Li
IT Specialist
@The Office
Message 9 of 12
thanks
Message 10 of 12
can you tell me what you mean exactly with this
Message 11 of 12
roland.r71
Command: STL
That one is easy.
The *error* trapping function calls the function (STL_VAR_RESET)
STL_VAR_RESET contains the line:
(command "_.layer" "set" old "")
... but (with newer acad) you can NOT use the regular (command ...) inside the error function.
Change that to: (command-s "_.layer" "set" old "") to make it work properly.
Note: this will only get rid of the message above, it will not solve you semantic problem. In fact, this means there is a problem which invokes the *error* function, but then it detects an error inside the *error* function and reports that instead.
Message 12 of 12
ivan_kilic5VMJD
Community Visitor
Community Visitor
Just wanted to chime in 5 years later - The same problem happened to me... After 6 hours of googleing - I solved this problem by changing screen resolution back to 1920x1080 🙂
