selection set by multiple handle
djurk_haas
djurk_haas
The code below selects the object with handle 5b6.
I need to make a selection set with multiple handles. Is that possible?
E.g. select the handle "5b6"and "132" at once.
Thanks in advance
(defun C:5b6-handle ( / handle
 ent )
  ;(setq handle (getstring "\nHandle to search for: "))
  (setq handle "5b6")
 (setq ent (handent handle))
  (if ent
    (sssetfirst
 nil (ssadd ent))
  ;Else
    (princ "\nNo such handle
 found.")
  (princ)
Moshe-A
@djurk_haas hi,
check this one:
cheers
moshe
(defun c:select-by-handle (/ ss ent)
 (setq ss (ssadd))
 (foreach handle '("5b6" "132" "bcd1" "fa45" "20a" "20b" "20c" "209")
  (if (setq ent (handent handle))
   (ssadd ent ss)
 ); foreach
 (if (> (sslength ss) 0)
  (sssetfirst ss ss)
  (princ "\nNo such handle(s) found.")
 (princ)
l.nikiforov
When the number of objects to select is large enough, I use the following command, which is much faster than iterating in a loop (especially, if you use ActiveX interface), for example:
"_SELECT (HANDENT "1A2727") (HANDENT "1A2725") (HANDENT "1A2723") (HANDENT "1A2721") (HANDENT "1A26E7")"
and don't forget to deselect everything after executed actions by following command:
"(sssetfirst nil nil)"
braudpat
Hello @djurk_haas
A similar routine "ZH_Sel" from GC (gile)
You can give many handles delimited by commas, and the routine "ZH_Sel" select them
and you can say : Next , Previous , All - And the zoom is automatic ...
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
