Selection Lisp counting objects selected
Message 1 of 10
I have a simple lisp that selects (and holds using sssetfirst) Mtest & Text.
I would like it to display on the command line how many objects are selected, I cannot get it to do this.
My code has the offending line blanked off using ;;
It works fine with the line not used & no variables declared
(defun C:SELECT_TEXT ( /sset)
(sssetfirst nil (ssget '((0 . "TEXT,MTEXT"))))
;;(princ (strcat "\n "(itoa (sslength sset)) items selected"))
(princ)
Replies (9)
Message 2 of 10
Hi sbanister,
His lack of space beetwen / and variable and your variblable is not used (no setq in your programme).
Try this code :
(defun C:SELECT_TEXT (/ sset)
(setq sset (ssget '((0 . "TEXT,MTEXT"))))
(princ (strcat "\n" (itoa (sslength sset)) " items selected"))
(princ)
The same shortly without variable.
(defun C:SELECT_TEXT ()
(princ (strcat "\n" (itoa (sslength (ssget '((0 . "TEXT,MTEXT"))))) " items selected"))
(princ)
Sorry for my english I'm french.
Olivier
Message 3 of 10
Hi sbanister,Oliver
Oliver's code is forcing user to select text, it is not going to count how many objects are already selected, because he removed sssetfirst.
If I understand well sbanister want to count how many text objects are selected.
This is the version with sssetfirst:
(defun C:SELECT_TEXT ( / sset)
(sssetfirst nil (setq sset (ssget '((0 . "TEXT,MTEXT")))))
(princ)
Sbanister, problem with your code was, beside missing space while localizing sset variable, there was no definition of the same.
You need to use setq sset , to define this variable and store selection set in it so, that you could later use sslength to see the number of objects in selection set. Second problem was in strcat function, which is connecting strings in one. You need to put " after itoa function.
 Hope this help,
dicra
Message 4 of 10
@Anonymous wrote:
Hi sbanister,Oliver
Oliver,
Sorry my mistake, I just made few tests, looks like there is no need for sssetfirst in this code.
Hope you don't mind.
dicra
Message 5 of 10
hmsilva
Hi sbanister,
in addition to what Olivier have pointed out, 'the lack of space beetwen / and variable', when we code, is essential to check/validate, the return from a function, before providing that return to to another function as argument.
In your code, if the user press enter before select any object, the code will throw an error as '; error: bad argument type: lselsetp nil'...
I would suggest something like this:
(defun C:SELECT_TEXT (/ len sset)
  (if (setq sset (ssget '((0 . "TEXT,MTEXT"))))
    (princ (strcat "\n" (itoa (setq len (sslength sset))) (if (> len 1) " items" " item") " selected"))
    (princ "\n 0 items selected")
(princ)
Hope that helps
Henrique
Message 6 of 10
Thanks both of you, Dicra's code sorted it though as I wanted the selection to remain selected. Hence I used sssetfirst.
Very useful if I need to quickly delete or copy text from a congested area of a drawing
Message 7 of 10
sbanister, Your welcome,
I would suggest you, to use Henrique's code, because of , what he is saying for the errors which are possible, when there are no text objects in selection set.
dicra
Message 8 of 10
I take your point, but it doesn't retain selection (sssetfirst)
Message 9 of 10
If you insist for sssetfirs, whit Henrique's remarks for error, maybe something like this:
  (if sset
    (princ (strcat "\n "(itoa (sslength sset))" items selected"))
  (princ)
dicra
Message 10 of 10
Spot on, thanks Dicra.
