Get info about current SNAPANG value - error 'bad argument type: FILE'
recently I worked a lo about lisps based on SNAPANG command
(see here:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisps-whichs-base-is-snapang-quot-joi...
and I wrote a lisp which inform in the CommandLine about the current SNAPANG value (it is NGINF1). But it failed to work properly. So I modified it and get NGINF2.
So I did in the case of HNGINF here:
http://forums.autodesk.com/t5/autocad-2010-2011-2012/why-instead-of-hpang-a-number-between-0-and-1-i...
- I also converted the angle in radians to degrees.
But this time, in the case of NGINF2, it doesn't work.
There is error in CommandLine - how looks prompt about this error like, is in the lisp code below.
;Command: NGINFRAD
;; error: bad argument type: FILE 0.611994
; gives result in Radians
(defun c:NGINF1
  (/ CurAng)
  (setq CurAng (getvar "SNAPANG"))
  (princ "\nCurrent SNAPANG value is equal to: " CurAng)
;Command: NGINF
; gives good result in decimal Degrees
(defun c:NGINF2
  (/ CurAngRad CurAng)
  (setq CurAngRad (getvar "SNAPANG"))
  (setq CurAng (* (/ 180 PI) CurAngRad))
Could you please tell me what is wrong? What should I change?
Ajilal.Vijayan
You need to use strcat and rtos.
So the princ line will be like this.
  (princ (strcat "\nCurrent SNAPANG value is equal to: " (rtos CurAng 2 3)))
Thank you. This tip was useful.
But after I used lisp with your correction:
(defun c:NGINFok
;  (princ "\nCurrent SNAPANG value is equal to: " CurAng); it gives error
(princ (strcat "\nCurrent SNAPANG value is equal to: " (rtos CurAng 2 3))); it is correct
 In the CommandLine there was doubled prompt:
"Command: NGINFOK
Current SNAPANG value is equal to: 0"\nCurrent SNAPANG value is equal to: 0""
So I had soon the knowledge what to do in order to have not doubled prompt, because I had such situation and on this forum someone helped me.
So I added "(princ)" nad now it works perfect.
And this is our lisp:
; Works properly
; NGINFOK
(defun c:NGINF
(princ)
Thanks for your help.
