Now I use Google Chrome and when I click on "Options", the menu is shown 🙂
Before I used Mozilla Firefox and probably it has an error.
There are my lisps from previous post.
(DEFUN C:HSCNG (/ CurHSC CurHANG)
(setq CurHSC (getreal "\nSet Current HatchScale for: "))
(setq CurHANG (getreal "\nSet Current HatchAngle for: "))
(COMMAND "HPSCALE" CurHSC )
(COMMAND "HPANG" CurHANG)
(DEFUN C:HSCNGDEF (/)
(princ "\nSet current HatchScale for 1, and current HatchAngle for 0")
(COMMAND "HPSCALE" "1")
(COMMAND "HPANG" "0")
(DEFUN C:HSCCNGG (/)
(princ "\nChoose HatchPatterns to change HatchScale for HatchScale you setted")
(princ "\nand to change HatchAngle for HatchAngle you setted: ")
(setq zbior (ssget))
(COMMAND "_-HATCHEDIT" zbior "Properties" "")
(DEFUN C:HSCCNGG1 (/ HSC HANG)
(setq HSC (getreal "\nEnter value for HatchScale: "))
(setq HANG (getreal "\nEnter value for HatchAngle: "))
(COMMAND "_-HATCHEDIT" zbior "Properties" "" HSC HANG )
; DEF = DEFault
(DEFUN C:HSCCNGGDEF (/)
(princ "\nChoose HatchPatterns to change HatchScale for 1")
(princ "\nand to change HatchScale for 0")
(COMMAND "_-HATCHEDIT" zbior "Properties" "" "1" "0" )
(DEFUN C:HSCCNGGCUR (/ Radians->Degrees CurHSC CurHANG)
; Default, Autocad works on HatchAngle in Radians.
; In purpose to tell to Autocad, that it should give me HatchAngle in Degrees,
; not in Radians, this "Radians->Degrees" function is needed;
(defun Radians->Degrees (numberOfRadians)
(* 180.0 (/ numberOfRadians pi))
(setq CurHANG (Radians->Degrees (getvar "HPANG"))) ; CurHANG = Current Hatch ANGle
(setq CurHSC (getvar "HPSCALE")) ; CurHSC = Current Hatch SCale
(princ "\nSelect Hatch Patterns to change their HatchScale for the Current HatchScale")
(princ "\nand to change their HatchAngle for the Current HatchAngle: ")
; (princ "\nWybierz Hatch'e do zmiany HatchScale na bieżącą")
; (princ "\noraz do zmiany HatchAngle na bieżący: ")
(COMMAND "_-HATCHEDIT" zbior "Properties" "" CurHSC CurHANG)
(DEFUN C:HNGGCUR (/ Radians->Degrees CurHANG)
(princ "\nSelect Hatch Patterns to change their HatchAngle for the Current HatchAngle: ")
(COMMAND "_-HATCHEDIT" zbior "Properties" "" "" CurHANG)
(DEFUN C:HSCINF (/)
(princ "\nCurrent HatchScale is equal to: ")
(getvar "HPSCALE")
;Działa
; RADTODEG = RADians TO DEGrees
; HNGINFRADTODEG
(DEFUN C:HNGINF (/ Radians->Degrees CurHANG)
(princ "\nCurrent HatchAngle is equal to: ")
CurHANG
; CURHANG = CURrent Hatch ANGle
Thank you all for help.
