Select rectangle and draw 2 diagonals
a.tawkXHKN6
Message 1 of 12
a.tawkXHKN6
Is there AutoLisp that select rectangle or square and automatically draw 2 diagonal polylines?
Replies (11)
Message 2 of 12
ВeekeeCZ
Never heard of Google? It's just a matter of seconds to find plenty of solutions. eg THIS
Message 3 of 12
a.tawkXHKN6
it doesn't accept rectangle selection. only polyline selection works here.
Message 4 of 12
ВeekeeCZ
Post a dwg of what you mean.
Message 5 of 12
Kent1Cooper
A reasonable assumption, since what the RECTANG command makes is a Polyline.  What kind(s) of object(s) are your rectangles?
>Here< is another, but also one that wants only closed four-segment Polylines.
EDIT:  If they are, for example, Blocks whose contents are rectangular, and when they are orthogonally oriented, the X-ing could be done easily enough based on their bounding boxes.  But not when rotated at non-orthogonal angles.
Why diagonal Polylines?  The XQ command in my link, and at least some of those in @ВeekeeCZ 's link, draw Lines -- is there some reason that Lines would not do?  It's easy enough to make them Polylines instead, but that would use more memory, so there should be a good reason for it.
Kent Cooper, AIA
Message 6 of 12
komondormrex
Hey,
Just for 4 vertices rectangle or square lw-plines.
;	komondormrex, feb 2023
(defun c:draw_rectangle_diagonals (/ ename_index ename_sset object)
	(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
	(repeat (sslength (setq ename_index -1
							ignore_empty_sset (while (null (setq ename_sset (vl-catch-all-apply 'ssget (list '((0 . "lwpolyline") (-4 . "&=") (70 . 1) (90 . 4))))
							ename_sset (cond
													(vl-catch-all-error-p ename_sset)
														(princ "\nCommand cancelled")
														(ssadd)
													t
														ename_sset
				(setq object (vlax-ename->vla-object (ssname ename_sset (setq ename_index (1+ ename_index)))))
				(if
					(and
						 (= "AcDbPolyline" (vla-get-objectname object))
						 (equal (distance (vlax-curve-getpointatparam object 0) (vlax-curve-getpointatparam object 2))
								(distance (vlax-curve-getpointatparam object 1) (vlax-curve-getpointatparam object 3))
								1e-8
						 (equal (angle (vlax-curve-getpointatparam object 0) (vlax-curve-getpointatparam object 1))
								(angle (vlax-curve-getpointatparam object 3) (vlax-curve-getpointatparam object 2))
								1e-8
						 (equal (angle (vlax-curve-getpointatparam object 1) (vlax-curve-getpointatparam object 2))
								(angle (vlax-curve-getpointatparam object 0) (vlax-curve-getpointatparam object 3))
								1e-8
						 (zerop (apply '+ (mapcar 'abs (mapcar 'cdr (vl-remove-if-not '(lambda (group) (= 42 (car group))) (entget (ssname ename_sset ename_index)))))))
						(progn
							(vla-addline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
										 (vlax-3d-point (vlax-curve-getpointatparam object 0))
										 (vlax-3d-point (vlax-curve-getpointatparam object 2))
										 (vlax-3d-point (vlax-curve-getpointatparam object 1))
										 (vlax-3d-point (vlax-curve-getpointatparam object 3))
				(princ)
	(vla-endaundomark (vla-get-activedocument (vlax-get-acad-object)))
	(princ)
Message 7 of 12
pendean
Community Legend
Community Legend
Perhaps you are unaware that RECTANG command creates a closed PLINE? There is no RECTANG object type in AutoCAD.
PLUS what you are looking to do is for an object in your file only has four LINE objects instead? So not LISP designed for PLINEs is going to work.
Share with us a portion of your DWG file with this "rectangle" in it please.  Or just use a basic LISP like this that requires two point selection https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/simple-lisp-for-cross-lines-between-... (and others further down that same thread).
Message 8 of 12
a.tawkXHKN6
please find the attached drawing
Message 9 of 12
Kent1Cooper
So it's a Polyline after all.  But it has an extra vertex in the left edge.  That's going to spoil routines that expect 4-vertex/4-segment Polylines.  Being orthogonally oriented, this one could be X-ed in using its bounding box, but that won't do at other orientations.  Better to fix the extra vertex situation, and use one of the routines that doesn't depend on an orthogonal orientation.
Kent Cooper, AIA
Message 10 of 12
pendean
Community Legend
Community Legend
You have a 5-sided 'rectangle'
Fix it
Message 11 of 12
ВeekeeCZ
If you have thousands of them, use OVERKILL to remove extra vertices.
Message 12 of 12
Sea-Haven
My $0.05 like the others just draw it correct.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values " "Length " 5 4 "6" "width" 5 4 "1")))
(setq L1 (atof (car ans)) L2 (atof (cadr ans)))
