Find the extension .dwg!
boyds86
boyds86
(defun c:TEST()
(setq A (getvar "dwgname"))
(setq B "dwg")
(if (equal (substr A (- (strlen A) 3)(strlen A)) B)
(command "QSAVE")(command "_.close" "y" ""))
(princ)
I am trying to build a lisp that if filename extention is .dwg will be close without save (for any change). Otherwise, It will be saved (specify that filename is .dxf).
But the lisp above is not working. It alway (command "_.close" "y" "") for any .dwg&.dxf.
Does anybody know the reason why?
Thank you for yourtime!
_gile
Hi
The substr function index is 1 based (i.e. the first character in the string is position 1).
You should write:
(if (equal (substr A (- (strlen A) 2) (strlen A)) B) ...)
Or, simply:
(if (= (vl-filename-extension A) ".dwg") ...)
Gilles Chanteau
GileCAD
GitHub
boyds86
Wow! It is great, Thank you very much!
WeTanks
the address where the file is saved,
Can it be added as a fixed place?
For example, C:\1
(defun c:TEST()
(setq B "dwg")
(if
(command "QSAVE")
(princ)
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
