script doesnt' finish running (Accoreconsole)
MANTONIOPM
Message 1 of 12
MANTONIOPM
Hello, I have a problem.
Script doesn't stop running when I run it with accoreconsole. I would like to know what part of the Run.bat or layereval.scr code I have to modify so that when I get to the last drawing in the folder it doesn't start again with the first one.
I would be very grateful if someone who knows how to use accoreconsole could help me
Replies (11)
Message 2 of 12
paullimapa
I only see QSAVE in the script.
Any reason why you didn't include CLOSE command at end of script?
Paul Li
IT Specialist
@The Office
Message 3 of 12
MANTONIOPM
Hi, thanks for your response. The result of putting CLOSE in the script is the same: the script doesn't stop when it reaches the last file, continuing again with the first one.
Message 4 of 12
paullimapa
for troubleshooting purpose perhaps try following:
1. create folder directly under C: drive like Test and modify bat to run in this new Test folder
2. place just 3 dwgs in Test folder
3. Run bat file again and see what happens
Paul Li
IT Specialist
@The Office
Message 5 of 12
MANTONIOPM
Before writing in this forum I already tried in C. In any case, it would not be a good solution, because the dwg files with which I am going to work will be on a server. I think the BAT file is missing some code to end the script when it goes through all the files in the folder.
Message 6 of 12
paullimapa
You can try alternative bat file construction as demonstrated here
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/accoreconsole-batch/td-p/8487768
Paul Li
IT Specialist
@The Office
Message 7 of 12
paullimapa
in dos batch file, not sure why you you would need at the end: /l en-US
do you know what this is supposed to do?
Paul Li
IT Specialist
@The Office
Message 8 of 12
MANTONIOPM
Trying with that code accoreconsole fails, while with mine it doesn't. The only thing that I can't get it to stop when it reaches the end, because otherwise it works for me
Message 9 of 12
MANTONIOPM
/l en-US is the language
Message 10 of 12
paullimapa
Would it make a difference if this was not included in the batch file?
Paul Li
IT Specialist
@The Office
Message 11 of 12
MANTONIOPM
there is no difference, the script continues to do the same
Message 12 of 12
paullimapa
I’m unable to reproduce your problem on my end. I even created matching folder names. I even tried a different but still local drive. So there’s nothing wrong with the batch or script file. The only difference really is your apps or plugins you have loading with your AutoCAD and your dwgs which are located on a mapped drive. So if you can just create a test folder on your local drive and copy the same three test dwgs over and try that
Paul Li
IT Specialist
@The Office
