Select Lines Based on X Value Only
kpennell
kpennell
Is there a way to select lines based on a known X value?
Something like....
(setq LinesAt300 (ssget "X" '((10 300.00 ? ?))))
There are lots of other entities in the way, so "WP" and sorting through all the entities is not that preferable.
Ranjit_Singh
Use -4 dxf code
(ssget "_x" '((0 . "line") (-4 . "=") (10 300 0 0)))
The zeroes in (10 300 0 0) are only for syntax, doesn't mean you are finding lines with a starting point of 300,0,0. You use 0 or any other number but cannot use ?  If you want to also test for y and z values then do something line (-4 . "=,>,*") The function of >, * should be pretty obvious. There are also binary operators that can be used in -4 dxf code.
SeeMSixty7
@Ranjit_Singh I did not know about the 0's on the other values of the point. That's great. You have taught me something twice today! SCORE!
@kpennell Since lines can have either end point at the xpoint I expanded on Ranjit's code to include the 11 code.
(setq myss (ssget "X" (list (cons 0 "LINE") (cons -4 "<OR")
			              (cons -4 "=") (cons 10 (list 10.0 0 0))
			              (cons -4 "=") (cons 11 (list 10.0 0 0))
			              (cons -4 "OR>")
Good Luck,
john.uhden
If I recall correctly, you can specify both x and y or even x, y, and z in one filter, as in
'(-4 . "=,=,=") '(10 10.0 30.0 0.0)
including mixing in >, <, >=, etc.
John F. Uhden
