extra attribute value from drawings to excel file
Bin2009
Bin2009
I have batch of drawings, need to extra about 3 TAG value from one attribute block in each drawing, (each drawing only have one this block), and hope the out put will be a excel file,like below,
better can run the lisp for all drawings under one fold and without open the drawing:
                             TAG1        TAG 2        TAG 3
drawing 1             xxxx             xxxx        xxxx
drawing 2             xxxx             xxxx        xxxx
drawing 3             xxxx             xxxx        xxxx
I tried DATAEXTRACTION in autocad, but looks complex, is a possible a simple lisp can do that?
Thanks in advance.
Bin
pbejse
@Bin2009 wrote:
I have batch of drawings, need to extra about 3 TAG value from one attribute block in each drawing, (each drawing only have one this block), and hope the out put will be a excel file,like below...
Thanks in advance.
Bin
Give us an idea how many?,
Not exactly Excel output but the next best thing. CSV or ACAD_TABLE.
Not at all, If you have Scriptpro and a DXE file, then yes DATAEXTRACTION should work. [ have to admit never tried DataExtraction with script before ]
Not a simple code as one might think, but rather a super duper complex code , just kidding 🙂 Yes its doable
