Select a point or object
C.Utzinger
Message 1 of 12
C.Utzinger
HI
I'm looking for a code where I can with one user Input get a Point OR an object.
What i want to do is when i just pink a Point then it will insert the block with attributes or when the block allready exists, select the this block and change the attributes.
Please help :).
Regards
Replies (11)
Message 2 of 12
ВeekeeCZ
Use (nentselp) function.
(defun c:ReselectionWithPoint ()
  (if (and (setq pnt (getpoint "\nSelect the point"))
           (setq ent (nentselp pnt))
    (cond ((= (length ent) 4)
           (setq ent (car (cadddr ent)))
           (sssetfirst nil (ssadd ent)))
          ((= (length ent) 2)
           (setq ent (car ent))
           (sssetfirst nil (ssadd ent))))
    (princ "\nNo entity under the point"))
  (princ)
Message 3 of 12
C.Utzinger
HI
I have the code like below.
Is there a better way to Change the block attributes?
And i don´t understand all the things the command "_.attedit" asks me.
I send you the dwg with the block. I just want to select the block an Change with one user Input both letters or numbers.
Thank you.
(defun c:<Test7 ( / *error* BEingabe oATTREQ oATTDIA Attrib pnt ent lay cmd BEingabe) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg))) (setvar 'CLAYER lay) (setvar 'CMDECHO cmd) (setvar 'ATTREQ oATTREQ) (setvar 'ATTDIA oATTDIA) (princ)) (setq lay (getvar 'CLAYER) cmd (getvar 'CMDECHO)) (command "_.-LAYER" "_m" "-I-Schnittbezeichnung" "_co" "6" "-I-Schnittbezeichnung" "") (setq oATTREQ (getvar 'ATTREQ) oATTDIA (getvar 'ATTDIA)) (setvar 'ATTREQ 1) (setvar 'ATTDIA 0) (setq Attrib 1) (if (and (setq pnt (getpoint "\nEinfügepunkt oder Schnittbezeichnung wählen: ")) (setq ent (nentselp pnt)) ) (cond ((= (length ent) 4) (setq ent (car (cadddr ent))) (sssetfirst nil (ssadd ent))) ((= (length ent) 2) (setq ent (car ent)) (sssetfirst nil (ssadd ent)))) (progn (princ "\nKein Objekt gewählt! ") (setq Attrib 2) (command "_.-insert" "spi-schnitt" pnt "1" "1" "" (setq BEingabe (strcase (getstring "\nSchnittbezeichnung angeben: "))) BEingabe))) (if (= Attrib 1)(command "_.attedit" ?????????)) (setvar 'CLAYER lay) (setvar 'ATTREQ oATTREQ) (setvar 'ATTDIA oATTDIA) (prin1) ) ; end of defun
Message 4 of 12
C.Utzinger
This one works now for the last block i have insertet, but not for the last selection.
Please help...
(vl-load-com)
    		(princ))
	(defun LM:vl-setattributevalue ( blk tag val )
    		(setq tag (strcase tag))
    		(vl-some '(lambda ( att )
                (if (= tag (strcase (vla-get-tagstring att)))
                  (progn (vla-put-textstring att val) val)))
             	(vlax-invoke blk 'getattributes)))
  	(setvar 'ATTREQ 1)
  	(setvar 'ATTDIA 0)
	(setq Attrib 1)
          	((= (length ent) 2)
    	  (progn
  		(setq Attrib 2)
			BEingabe)))
	(if (= Attrib 1)(progn  (setq en-blk1 (entlast))
				(setq BEingabe (strcase (getstring "\nNeue Schnittbezeichnung angeben: ")))
				(LM:vl-setattributevalue (vlax-ename->vla-object en-blk1) "rechts" BEingabe)
      				(LM:vl-setattributevalue (vlax-ename->vla-object en-blk1) "links" BEingabe)))
	(prin1)
) ; end of defun
Message 5 of 12
C.Utzinger
I am so stupid, now it works!!!
Ok... Can I omit the variable "Attrib"???
And sometimes when I select the block (for example near the Attribute) it doesn´t work, because it don´t select the block. Can you fix this?
 Kind regards...
(vl-load-com)
    		(princ))
  	(setvar 'ATTREQ 1)
  	(setvar 'ATTDIA 0)
	(setq Attrib 1)
          	((= (length ent) 2)
    	  (progn
  		(setq Attrib 2)
			BEingabe)))
	(if (= Attrib 1)(progn  (setq en-blk1 ent)
	(prin1)
) ; end of defun
Message 6 of 12
ВeekeeCZ
I've rewritten it. This way it's more nature, I think.
(vl-load-com)
    (princ))
  (setvar 'ATTREQ 1)
  (setvar 'ATTDIA 0)
  (setvar 'CMDECHO 0)
  (if (setq ent (car (entsel "\nEinfügepunkt oder Schnittbezeichnung wählen <insert new>: ")))
    (progn
      (LM:vl-setattributevalue (vlax-ename->vla-object ent) "rechts" BEingabe)
      (LM:vl-setattributevalue (vlax-ename->vla-object ent) "links" BEingabe))
    (progn
      (princ "\nSpeciefy point for block: ")
      (command "_.-insert" "spi-schnitt" pause "1" "1" ""
               BEingabe)))
  (prin1)
  ) ; end of defun
Message 7 of 12
C.Utzinger
OHH!!!
Thank you that's great!!!
Kind regards.
Christian
Message 8 of 12
john.uhden
My ancestors came from Essen, but I have no idea what Schnitselberg is, except maybe a frankfurter.  Luckily BeeKeeCZ is multilingual.
John F. Uhden
Message 9 of 12
C.Utzinger
LOL XD XD XD
Message 10 of 12
ВeekeeCZ
I can order a Schnitzel mit Pommes if we are in Austria but nothing more. I can understand the basics from my school years, but that's not really enough. My parents thought that would be a good idea speak as our 2 neighbors does and Germany is our biggest business partner.. but it was wasted time.. Even with a German is better to speak in his second language.. then we are even. Fortunately nowadays there is the Google translator so I can understand a German, Portuguese, Russian, even a Chinese.. 😉
Message 11 of 12
C.Utzinger
LLLLOOOOOLLLL
Message 12 of 12
john.uhden
@C.Utzinger wrote: "LOL XD XD XD"
Ahah.  I am no dumbkopf.  I CAN understand German!  You are cursing at me, right?
John F. Uhden
