help to get geometry position values for points on drawing
miroslav.pristov
miroslav.pristov
Hello all I have drawing in georeferenced system
I need to get geometry values for some points on drawing.
What I usually do? I pick each point, open properties, copy position X, paste in excell, etc.. the same i do with Y and Z position.
If u have one point this is ok but if You have 50 points or more its quite boring and i can make error somewhere.
I didnt find any command which will help me to simplify this procedure, i ll try to find similar lisp, but i didnt find it.
So can someone please help me and make me a lisp for this. to choose points in a row like point 1, 2, 3, 4, 5, etc and when i choose the last one the lisp made me a table in Autocad which will look like this bellow.
point                X                       Y                            Z
1             positionX1           positionY1            position Z1
2             positionX2           positionY2            position Z2
LAST      positionXLAST      positionYLAST     position ZLAST
Any help will be great thank you.
ВeekeeCZ
Points to Excel. This works for me.
(defun c:Points2CSV ( / *error* file txt pnt lst i)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if file (close file))
    (princ))
  (setq i 0)
  (while (setq pnt (getpoint (strcat "\nPick a point no " (itoa (setq i (1+ i))) ": ")))
    (setq lst (cons (cons i pnt) lst)))
  (if (and lst
           (setq file (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-TxtExport.csv") "a"))
           (write-line "n,x,y,z" file)
    (foreach e lst
      (setq txt (strcat (itoa (car e))
                        (rtos (cadr e) 2 8)
                        (rtos (caddr e) 2 8)
                        (rtos (last e) 2 8)))
      (write-line txt file)))
  (*error* "end")
miroslav.pristov
actually it wont work
i dont know how to stop choosing points. When i stop it by clicking enter or esc nothing happens. the CAD is just ready for new command
ВeekeeCZ
Stop it usual way, hit enter. You can change this line....
(while (setq pnt (getpoint (strcat "\nPick a point no " (itoa (setq i (1+ i))) "<done>: ")))
It creates a csv at the place where is your dwg file saved.
I assumed that csv uses semicolons in your country, but change that to comma if I am wrong. - you'll find where.
miroslav.pristov
it work just what i need but i have problem with excel file. nxyz are in diferent cells in first row and its ok, but values bellow are not. they are in form n;valuex;valuey;valuez in first cell of next row
i try to change ";" as you say to "," but nothing happens, everything the same.
miroslav.pristov
sorry my fault it works perfect i miss parenthesis
ВeekeeCZ
Good you found it! Posting the final code for the record. I added one more thing to reverse the list to make it start from the beginning...
    (princ))
  (setq i 0)
  (while (setq pnt (getpoint (strcat "\nPick a point no " (itoa (setq i (1+ i))) " <done>: ")))
  (if (and lst
           (setq lst (reverse lst))
    (foreach e lst
                        (rtos (cadr e) 2 8)
  (*error* "end")
